Sky InsuranceVolks Autos
Results 1 to 8 of 8
    Jan 2011
    Glasgow
    239
    S3 full Haldex change (How much oil ml required)
    My audi S3 is due an full Haldex oil and filter change. Ive got the removal tool, filter and one 275ml tube of haldex oil. Ive got one question. How much oil does the haldex require is 275ml enough from empty? Ive seen on the internet i need 1litre or 600ml or 3 x 275ml tubes? Im unsure what i need. Any help would be excellent. Also there is a separate part of the haldex that uses diff oil? How much and what oil is required there? Thank you.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,785
    I'm pretty sure it's one whole tube (if it's from VW/Audi).
    The rear diff (often confused) is 1L and gearbox is 2.6L.
    This is from memory...
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    drain when the haldex is warm, use all the oil supplied in the tube...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    1 x tube of haldex oil (its hydraulic oil) required for the change...
    Rear diff uses 75W90 semi or fully synth gear oil... can't remember off hand the amount (1 to 1.5 ltrs springs to mind)
    <tuffty/>
    Jan 2011
    Glasgow
    239
    Yeah yous are correct it's 1 litre in the diff and one tube 275ml for the Haldex thanks for the help will be getting done tomorrow :D
    Apr 2012
    605
    and the tool is there only one tool that can be used??
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    You mean the filter removal tool? If so yes, use it!
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,785
    A friend of mine says he just uses some adjustable pliers (the large ones) rather than the tool, seen as you're throwing the filter away anyway. I suspect the tool is easier though, just pricy for what it is. Hardly much R&D to a bent bit of metal and a ring spanner end.
  1. a4 tdi 2002 cam belt change ...how much?
    By codrock in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th February 2009, 00:04
  2. How much oil!!
    By consilio in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st August 2008, 19:08
  3. How Much Oil to top up? (2.0 TDI)
    By giblets46 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st May 2008, 13:14
  4. How Much Oil does the 2.0T Take?
    By Leetaylor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2007, 21:43
  5. cam belt change...... how much?
    By shufti in forum Diesel forum
    Last Post: 7th December 2006, 23:20
