Results 1 to 8 of 8
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Revo sps settings - suggestions please.
    I'm hoping someone with a little more knowledge / experience can give me a little guidance
    I have an AMK s3 with revo stage 1 map and a sps+ adjustable switch
    I have the following modifications:
    Fmic
    Milltek cat back
    Relentless manifold down pipe and sports cat
    B5 tip with cone filter and heat shield
    TFSI coil packs
    Forge FMDV008 recirc DV
    I am running the standard K04 at the minute and run on super unleaded.
    I do plan and getting the Revo upped to stage 2/3.
    What settings would be recommended for the sps+. ?
    Thank you.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    mine is on stage 2 software and was set to B7 T7 F4 from the remapper
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Will that be a different range on stage 2 tho?
    2001 S3 (AMK)
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    not sure to be honest but i was under the impression it was only worth teaking stuff once you had gone to stage 2 software
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    687
    I have S3 BAM with B5 TIP, Jetex Cone, Forge 008 DV, and Revo Stage 1.
    The settings Awesome GTI gave me were:
    Boost - 8
    Timing - 4
    Fuelling - 6
    If you already have Revo Stage 1, I am sure its only a £50-60 charge to get Stage 2. Not 100% on that though
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    yup £60 to upgrade to stage 2 revo if you are already running stage 1 and have a proof of purchase
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    687
    Do they actually change the map, or just the settings when you go from Revo Stage 1 to Revo Stage 2?
    [8L BLOG] [8P BLOG]
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    They upload a new map.
    Edit:
    Im running stage to settings
    Boost 6
    Timing 4
    Fuel 0 as it dont do anything on bam ecu's. so i was told...
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
  1. Revo Stage 2+ sps settings for s3??
    By swatchuk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th January 2012, 13:33
  2. REVO stage 1 - Performance mode setting help please....
    By elton121272 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2010, 12:46
  3. AMD Oneclick / Revo SPS
    By auroan in forum Diesel forum
    Last Post: 11th August 2005, 22:49
  4. Revo SPS / AMD One Click
    By auroan in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th August 2005, 22:48
  5. A3 Tdi PD100 any suggestions please?
    By gilly35 in forum Diesel forum
    Last Post: 29th September 2004, 00:05
