AH FabricationsBadger5
Results 1 to 14 of 14
    Mar 2011
    Exeter
    90
    S3 Fuel Pump, can it be replaced on it own???
    hi guys, im looking at changing the fuel pump on my 2001 amk s3 and was wondering if the fuel pump can be removed from the fuel pump/sender unit and replaced on its own or if the whole unit has to be replaced.
    i have had a search around but cant find a definative answer.
    many thanks
    56 plate 8P S3, Phantom Black, RNSE, Cruise Control, Parking Sensors, Adaptive Bi Xenon Headlights, Interior Light Pack, FBMFSW, Center Arm Rest,
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You can change the pump on its own, but dont know if you can buy them like that, i would guess not...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    If you can buy one on its own then maybe but I doubt it will save you much money (guessing this is the reason for asking)...
    From personal experience and experiences expressed by others that have changed pumps then personally I would accept the inevitable and buy a genuine one... Westy found his 'aftermarket replacement' was next to useless so ended up buying an OEM one...
    <tuffty/>
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Quote Originally Posted by ;1705351
    <tuffty/>
    No mate that was the issue with the heater matrix. Someone else had the fuel pump issue
    I've learnt my lesson now and only get genuine kit but I do get healthy discounts.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    IGI
    IGI's Avatar
    Jan 2007
    Innerleithen, Scotland
    85
    Yes you can just replace the pump part of the unit ... i did... was easy to do when youve got the whole unit out. I got the pump part from Dingbro my parts supplier was way cheaper than Audi/TPS aint genuine part tho...however the old genuine part looked absolutely identical to the new one even in the small details like they ve come from the same suppling factory cant remember the brand but have the invoice somewhere
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Linky: Suspected Fuel pump/relay issues.
    My advice would be to buy an OE item from a dealer/TPS, if you have to buy from somewhere else then make sure you get the whole harness/carrier as it's loads easier to change the whole unit.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Mar 2011
    Exeter
    90
    Thanks for the advice guys. I'm not worried how complicated it is to replace the pump on its own as I'm a mechanic so that's not an issue. I was hoping the pump on its own was available and cheaper!!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    RIP S3dave
    May 2004
    nr Glos
    7,187
    Quote Originally Posted by jk_s3 View Post
    VDO pump.. so if the other guy can post the part number that would be helpful for all.
    I bought and fitted a pump only to an ibiza last week... fuel pump listed separately for an LCR... £60 approx From Euro's
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    IGI
    IGI's Avatar
    Jan 2007
    85
    Right i had a rake through my paperwork this is all i can tell you .... Fuel Pump part number XFP4041 and it cost me £176.31 + vat @trade pretty sure TPS wanted £230 ish + vat for the same part, i wouldnt guess at what the whole unit cost was
    I remember the pump came allready in a white plastic unit not bare as the pic above theres a connecting pipe for the other half of tank too
    The sender unit screws to the fuel pump unit, swap wires over and swap plastic pipes over for feed and return....be careful when swapping the plastic pipes over they are brick hard, i softened them with a gentle heat.... apart from that it didnt take long to do
    Hope this helps
    IGI
    IGI's Avatar
    Jan 2007
    85
    Quote Originally Posted by [Dave B] View Post
    Goes to show i was paying attention just noticed the linky lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    S3 pumps are rated at 4bar IIRC... that listing says its a 3bar
    <tuffty/>
    Mar 2011
    Exeter
    90
    Does anyone no for certain what the standard pump pressure is? 3bar or 4bar? I've found the pump that badger5 mentioned on euro car parts website but it states its a 3 bar pump. Thanks.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    std S3 is 4bar....
    <tuffty/>
  1. Front grill chrome trim/surround; can it be replaced on its own?
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th May 2011, 15:09
  2. A4 2.5tdi fuel pump replacement
    By sam1014 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th February 2010, 08:50
  3. Fuel pump replaced on 2.5tdi now wont pull diesel up
    By cobrascim in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st January 2010, 12:04
  4. Replacing fuel pump on 1.8T
    By Beef in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd July 2008, 09:54
  5. Fuel pump replacement
    By sakkie69 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2008, 12:56
