Sky InsuranceEM Tuning
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By Broken Byzan
  • 1 Post By badger5
Thread: Strange phenomenon - rapid increase in RPM
    Scullies's Avatar
    Feb 2012
    Dubai
    1,205
    I have started getting weird increases in rpm. It's usually in 3rd, 4th and 5th. Haven't tried 6th.
    What happens is when I accelerate sometimes the rpm rises from 2500rpm to 4000rpm as usual then the rpm shoots up from 4000 to 5500 very quickly but the car doesn't accelerate as fast as the rpm does. If you know what I mean.
    Other times it runs through the full rpm range as it would normally do, all the way to 6500rpm
    It almost feels like the clutch is slipping, could this be the case? If so wouldn't it happen on every pull?
    Any ideas on what could be causing this to happen. Could I log anything in vcds to see what is happening, if its ecu related?
    Sep 2012
    Bedford
    19
    Would have thought it was clutch related if the revs are going up a lot quicker than the speedo?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,205
    Quote Originally Posted by Adeyy View Post
    Mechanically ,that's what my little brain is telling me. I can't see how the crankshaft can turn faster and not drive the gearbox faster.
    Unless.............my car has massive huge amount of torque and all the wheels are slipping
    Reesy's Avatar
    King of the Mods. Apparently.
    East Sussex
    3,600
    Visit Reesy's Instagram Channel
    Clutch
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,892
    Quote Originally Posted by Reesy View Post
    Clutch
    he needs bigger brakes...
    now seriously it does sound clutch related
    k03s/k04 hybrid a3 275bhp 293lbft
    vr6 mk2 golf gti
    fellow north east members add your name to this list.
    http://www.audi-sport.net/vb/north-e...%2A%2A%2A.html
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    Definitely clutch. What happens if you accelerate hard from a standing start in the dry? I would expect the clutch to slip from what you're describing. I'm sure you can tell the difference between clutch slip and breaking traction.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,205
    Done a few launches and it pulls hard, cant really feel it slipping. The car accelerates according to the rpm.
    I think it only happens at speeds over 100km/h, when the power kicks in.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,637
    Visit s3 Hoggy's Instagram Channel
    Clutch mate definately
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Just in case anyone else hasn't mentioned it, it sounds like its the clutch.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    Maf, Coil packs ?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    sidelight bulb?
    Brodster likes this.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Scullies's Avatar
    Feb 2012
    Dubai
    1,205
    FYI, its was the 3rd wheel nut on the rear left wheel that was loose !!
    So how long you think I have until the clutch gives up? No more launches, I have ordered a 6 paddle clutch and it should be here around the 10th of November.
    I hope the clutch lasts till then
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    821
    Add Vex182 on Facebook
    Drive it carefully and I don't labor the engine and it should be fine. Accelerating in 5th from 30mph would be a no! Lol
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    3,991
    sidelight bulb?
    speaking of which
    Also in my professional clutch killing opinion (I kill them without even trying these days) CLUTCH!
  1. Rapid Shot RPM limiter cutting
    By Lawrie in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2012, 23:26
  2. Increased stationery RPM's on 2007 2.0 TDi (140) ?
    By Kriminal in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th December 2010, 13:17
  3. Strange Noise when reversing
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2009, 18:40
  4. Strange noise..
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2003, 00:44
  5. Strange noise - anybody got a clue !?
    By audi_girl in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:52
