EM TuningJMB Retrofits
    actualeddie's Avatar
    Feb 2012
    Waltham Abbey, Essex
    211
    Audi S3 prefacelift indicators
    Is it a common fault that the plastic that holds the indicators to the head lights snaps off? Had it on my nearside when i bought the car and today my offside is hanging off.
    I used silicone on the last nearside, but now they are both gone may aswell replace them. also the plastic on the actual nearside headlight is broken; so need a whole new set.
    If im spending out on these problems, is there an upgrade I should consider for example facelift lights?
    Thanks in advance guys
    Eddie
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,277
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I've had a pre facelift S3 for a while (4 year) and can't say it has been a problem for me....
    Cost of 2 x new headlight indicator units (£40ish) vs Cost of second hand facelift headlights (£3-400ish) Plus you have to mod the arch slightly to make the facelift lights fit properly.
    MrTackalakalaka's Avatar
    Jan 2012
    Truro, Cornwall
    426
    I've had the same problem with my indicator. Got fed up of it popping out so tried a DIY which lasts for a while then it just starts popping out again.
    i couldn't find replacement indicator units for the S3 but found a set of units on eBay for the A3. Only difference is you don't have the chrome part surrounding the bulb. Just an orange bit of plastic.
    Hope this helps
    Feb 2012
    211
    finally have some money to get replacements, ill just stick with original parts. Does anyone know if S3 and S4 lights are the same? would this fit?
    Audi A4 S4 Xenon 95-99 Headlight Headlamp LAMP NEW N/S PASSENGER SIDE | eBay
    Hard to find S3 lights
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,637
    S3 and a3 lamps are different. I got a set from a member here breaking his car. No problem since 8-)
  1. Audi B6 Avant indicator Running Lights
    By Olliecox in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2012, 14:38
  2. Audi A6 1.9TDi Indicator & Rear wiper issues
    By chris2009 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th April 2010, 22:55
  3. Can you fit the new audi a3 wing mirror with indicators onto a 53 plate?
    By Digzz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2009, 18:42
  4. Preface audi s3 front indicators ?!!
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2008, 17:28
  5. AUDI 100 Avant clear indicator lenses????
    By RCCatering in forum Classic Audi Forum
    Last Post: 6th March 2006, 09:18
