Volks AutosEM Tuning
Results 1 to 10 of 10
    niallraff's Avatar
    MW 3
    Mar 2011
    Ireland
    17
    Buying an s3 , which one to go for ?
    Hi guys i have just moved over to Brisbane Australia form N. Ireland and am interested in buying an S3 year 2000 - 2002, I have noticed there are a range of different engines available with them (APY OR BAM) . This is where i need you guys help . I will most likely be doing some performance and handling mod's. I hope to take the car around to 270bhp so what all would i need to upgrade to get within this target ? and what all is there to look out for when buying ? most reliable engine ? easiest moded ?
    Dpf delete Remap and Dsg remap 210bhp & 344lb/ft running clean
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Stickies....
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Just buy the best conditon one you find, all the engines remap up to about the same anyway, and conditon and spec always the key
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    get an AMK engine... beats you doing all the delets..
    get 270 is fairly simple bolt on mods... get an FMIC, B5 Tip, 007P DV forge a remap ... get the DP and catback changed and you should have your 270odd hp
    once you buy ur id advise gettting a VCDS scanner and check for rust on the roof rails..
    VAB
    VAB's Avatar
    May 2012
    Australia
    44
    I have an AMK and agree with Sevv - deletes are easy stuff and getting them running well is just a matter of following the stickies
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    But AMK do seem to suffer from head failures...
    Jan 2011
    Australia
    1,316
    just replace with a AGu AEB large port head anyway... its only 150-300 pounds its a joke when you think about a cost of an S3 in Oz.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    I logged 220gs/275bhp with B5 TIP + Jetex, a decent service and a stage 1 (unsure which) map.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    I'd go for one that was owned by someone on a forum like this one as it has probably been well looked after and serviced regularly also try and get one with some good mods like a good exhaust and coilovers as it may save you some money in the future when the modding bug hits lol!
    niallraff's Avatar
    MW 3
    Mar 2011
    Ireland
    17
    Thanks for all the comments guys. I have been reading alot on haldex race controllers and was wondering if anybody on hear has one fitted along with a rear lsd and arb's aswell . i imagine this would cure the understree alot ?
  1. Which one to go for?
    By New Age Driver in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2008, 18:43
  2. buying an a3, which one is the best ???.
    By Audi_nut in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2007, 00:36
  3. buying an a3, which one is the best ???.
    By Audi_nut in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th August 2007, 17:26
  4. ISP - which one best value for money??
    By Naresh in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 12th June 2005, 01:45
  5. Which one is best for my buck$
    By Mutinyno9 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st May 2004, 21:25
