JMB RetrofitsAH Fabrications
    colicabcadam
    a3 8l tdi 110 se ?
    hi all, on the look out for one of these tractors, been given an a4 b5 with a 110 engine in it and the economy is crazy
    is anyone aware of any potential problems that are common on these ? anyone know what boost they should run at in standard form ? and what boost when mapped ? will vcds the car, just looking for some pointers, caill will certainly have 150,000+ miles on the clock, in some cases as much as 200,000
    not interested in any of the PD engines for cost reasons, car needs to be cheap and cheerful and the 110's can be bought for under £1200
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Not much goes wrong with the AFN, same as most, oil coolers split, they have a VNT (some do) so check that isnt coked up causing an over boost issue, they will prob have a DMF so check that, apart from that they are good strong engines
    Although the PD is a great engine and if looked after is a more refind engine but thats just my opinion
  1. 98 A4 TDI(110)
    By fatbob in forum Diesel forum
    Last Post: 20th October 2005, 19:43
  2. 1997 A4 TDi 110 Immobiliser fault
    By Major_Ingram in forum General Technical / How To
    Last Post: 14th March 2004, 11:36
  3. ChIpping A4 1.9 Tdi 110 Quattro
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th September 2003, 12:49
  4. Chipping 1997 A4 Tdi 110 Quattro
    By Holywood in forum Diesel forum
    Last Post: 2nd September 2003, 17:35
  5. A4 TDi 110 OR PD 115 Which is Best?
    By 18ME in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2003, 00:44
