Badger5Monster Motorsport
Results 1 to 7 of 7
    Jun 2012
    57
    Revo Stage 2 Overboosting and random auto-resets on highway
    Hi Guys, couldn't find anything for this problem!
    Found that on 1st and 2nd gear, the maximum peak I get is about 1.2-1.3 bar (which is about 17.4 to 18.8psi), on 3rd, 4rd, 5th and 6th gear I get about 26psi and on highway when doing WOTs from 2-3000rpm and after a while it goes back to the correct boost (which is 1.3bar, told directly from revo).
    Happened also 5-6 times, that my Revo Remap auto-resets when I'm the highway, but only when doing long WOTs in 5th or 6th gear and from about 200 km/h onwards!
    In fact I see, on my boost gauge, the boost going from about 1.6-1.7 bar (which I think is A LOT for a std K04!) and suddendly feel a big loss of power and see the boost gauge go back to 0.8bar (which is the OEM boost).
    What do you think guys about that?
    Thank you in advance!
    RIP S3dave
    May 2004
    nr Glos
    7,166
    its not resetting its load dependant
    mroe load more torque request more boost..
    what revo settings in it? I will assume >6 on boost with what you describe
    other things to consider... if this has started happening after being ok.. post map.. Is split pipe or malfunctioning n75 - overboot and erratic boost can occur
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2012
    57
    Started doing that after a while, before it was ok!
    Maybe started it after mounting the boost gauge, but I don't think it can be that the problem!
    As remap setting, I honestly don't know which I have, I've always left the setting that the revo dealer put on.
    Which setting are reccomended? Considering I don't have a fmic?
    Feb 2012
    bedfordshire
    748
    Could it be the hose to the boost gauge if you have just fitted it and now having problems ?
    Jun 2012
    57
    Quote Originally Posted by dre_S3 View Post
    I don't know, but I don't think could be that! All is well tight and there are no leaks!
    I've put the boost gauge with the FPR, would be better to put it on the DV?
    RIP S3dave
    May 2004
    nr Glos
    7,166
    Quote Originally Posted by Golfer1991 View Post
    yes.. dont T off fpr... T off something less important..
    safer settings would start at b6t4
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2012
    57
    Just put these settings on the ECU:
    Boost 6
    Timing 4
    Fuel 9
    Will try tomorrow if it goes better!
    Anyway Bill, do you know a Home made method to do a Smoke test? Seems nobody here in switzerland does that!
  1. Pros and Cons of Revo Stage 1
    By Brodster in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th October 2011, 10:01
  2. Engine management after Revo stage 1 and forge DV
    By Farmer_Harry in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th September 2011, 10:24
  3. Rough estimate of power with Revo stage 2 and my mods?
    By DJ_Troopa in forum Sales Questions
    Last Post: 7th March 2010, 10:09
  4. Difference between revo stage 1 and 2
    By ash3435 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2010, 15:59
  5. Revo stage 2 yesterday and cambelt gone today
    Last Post: 9th December 2009, 13:33
