EM TuningMonster Motorsport
Results 1 to 7 of 7
    Dec 2011
    Bedfordshire
    127
    Fault code reader ecu question?
    Hi I bought a code reader for my v plate s3 on the ecu info
    it said
    vag no: 8L0920980B
    component:
    AB-KOMBIINSTR. VDO
    D05
    coding:01444
    wsc: 00411
    Then did it again now it says
    vag no: 8L0906018k
    component:
    1.8L R4/5VT
    0003
    coding: 05610
    WSC: 14647
    As you can see totally different can any one tell me why it has changed over night?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    the first one is the dash, second one is the ECU... different modules...
    <tuffty/>
    www.badger5.co.uk
    May 2004
    nr Glos
    6,948
    vcds for the win
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Dec 2011
    Bedfordshire
    127
    <tuffty/>
    Ok thanks can I tell if it's been remapped in the past would it have anything on the info?
    Dec 2011
    Bedfordshire
    127
    vcds for the win
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    VCDS = Ross-Tech: Home
    Best fault finding software for VAGs on the market... code readers aren't all that really...
    Easiest way is to check the boost level... if its over 12psi then its been mapped... with VCDS you could log airflow and that would tell you too... stage 1/2 maps are around 200gs of airflow (or more depending on mods), std airflow is around 180gs
    <tuffty/>
    www.badger5.co.uk
    May 2004
    nr Glos
    6,948
    Quote Originally Posted by jay1 View Post
    you may find google is quite a handy tool
    bill@badger5.co.uk
  1. Haldex ECU - Fault Code J492
    By Jonay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th December 2011, 16:26
  2. Fault code reader - which type ?
    By AudiJohn in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2011, 17:46
  3. 2 Fault Codes - Question
    By DenCar in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th June 2010, 22:55
  4. 1997 Airbag ECU fault and brake light question
    By Nick101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2010, 17:47
  5. Fault code reader/scanner
    By griswold in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th January 2009, 17:15
