    Apr 2012
    East Kilbride
    29
    Coolant sensor!!!
    Eveining all
    Looking for a bit of advice.
    My coolant level sensor comes on every now and again, normally 1st thing in the morning when cold. I trun the engine off then back on again and it clears
    Any one got any ideas?
    2001 AMK S3.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    Levels too low... top up in the expansion bottle...
    <tuffty/>
    Apr 2012
    East Kilbride
    29
    Thought that Tuffy but every time the warning flags up I check and its in between the lines.
    Weird one, only in the cold too.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,411
    If it goes off after you drive down the road or when it warms up, then just top it up a little. Mine does this, I just live with it, checking it occasionally.
    You've got to have a laugh!
    Apr 2012
    East Kilbride
    29
    Cool
    Cheers for that guys.
    I will top up see if it helps, fingers crossed.
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Coolant level sensor could be faulty, check the wiring to it, but the sensors do fail, you can try and clean it up but unfortunatly to replace it means changing the header tank, not espensive but not as straight forward as replacing a sensor.
  1. Coolant Sensor warning
    By SanityClause in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2008, 12:11
  2. My A3 1.8T Coolant Sensor
    By ricje in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2007, 19:41
  3. Engine Coolant Sensor problem reveals oil in intercooler
    By alanmclean1974 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th October 2006, 22:43
  4. Lumpy Idle - coolant sensor?
    By recomdos in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2005, 09:09
  5. Help with TBB, f-hose, the coolant sensor upgrades
    By imported_Townshend2372 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th August 2004, 11:47
