Thread: Intercoolers
    Nov 2011
    Sturminster Newton
    190
    Intercoolers
    Right heres the situation after some thought and a quick buy of a k04 for my tqs, to do a conversion on as im getting bored of the power well not bored just feel like im missing out on the potential power .
    so the k04 is hopefully going to beachbuggy soon for new bearings, so that should be all good when it comes back.
    Im after about 250-270 hp, as I will be running the k04 on mostly stock s3 parts (manifold, injectors and possibly tip), the only thing that is going through my mind is fmic do i really need a wellycooler or could i go for the next size down, and keep the smic and use them in tandem or is that a silly idea, and i should just get the wellycooler and do it properly.
    so on the shopping list at the moment is
    k04 manifold
    tip
    S3 injectors
    maf
    Heatshielding
    will the S3 stock exhaust cope with 250-270 or will I need to get something else.
    so when all this is done i will have some k03s parts that need a new home if anyone is interested.
    A3 1.8TQS Minge blue
    Mods: AP coilovers, Strut Brace, Merc wheels, S3 brakes, hopefully going BT soon
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    There is a smaller version of the toyo cooler available from what I understand but I wouldn't use the SMIC inline as this will cause too much pressure drop... whatever cooler you go for don't go smaller than 60mm (63mm ideally) for the inlets...
    The welly cooler is not expensive though...
    <tuffty/>
    Nov 2011
    Sturminster Newton
    190
    Thanks Tuffty for the answer, it wasn't about cost of the cooler just the size of it as I wasn't planning huge power just more , I kinda didn't want to have to start cutting bumper/crash bar to fit the cooler, I would also like to retain fogs aswell.
    just a few ive been looking at
    270734257644
    400159814481
    200791391130 --- 2.5 --- IC5006
    just a few options wondering if anyone had any experience with any or similar size cores
    phil miller's Avatar
    Sep 2012
    Devon
    843
    FMIC is the way forward, the cooler ive got is 88mm wide which has meant ive had to 'trim' the lower part of the bumper, if you get the welly that is 76mm wide then i would have thought it would be very little trimming to the lower half
    Nov 2011
    Sturminster Newton
    190
    Spot on cheers phil, that mani is all good car is running good again till the k04 goes on
  1. Part 1 - Front Mont Intercooler
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2004, 09:13
  2. CO2 Intercooler spray kits for FMIC *URGENT*
    By Stuart_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2004, 19:49
  3. S3 front mount intercooler
    By martin3310 in forum Tuning
    Last Post: 14th May 2004, 09:12
  4. A3 UPRATED INTERCOOLER
    By ANDYTQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2004, 16:46
  5. S3 trubo>intercooler pipe fiot A3?
    Last Post: 23rd September 2003, 15:09
