    Crazypete00's Avatar
    Oct 2007
    266
    Annoying Vibration
    Hi,
    ive had a really annoying vibration on the front passenger side for along time now. it seems worse when i first get in the car for a mile or so and then settles down but then gets gradually worse as i pick up speed. i dont feel it very much on the drivers side and i only get a small amount of vibration through the steering wheel. but if you sit in the passenger seat its like sitting on a tumble dryer just constant vibration.
    recently ive had wheel bearing replaced, new pads and disks, new top mounts and dogbone mount. nothing seems to have sorted it. anyone got any ideas?
    Yohan87's Avatar
    May 2011
    404
    Wheels balanced and all tyre pressures correct?
    Oct 2007
    266
    ye had new tyres and re balanced about 3-4 months ago, i had the vibration before that and i still have it now. and ye pressures are all good.
    Yohan87's Avatar
    May 2011
    404
    Drive shaft or cv joint?
    Does it get worse and certain speeds then better at even higher speeds?
    I.e. really bad at 50mph but ok at 80mph (on a private road officer).
    Oct 2007
    266
    its hard to say, i dont notice it so much when im driving. i would say it gets worse at 50mph but doesnt get any worse after that, so stays the same.
    ive had cv go before and i usually get a knocking sound when turning which i dont have
  1. Annoying vibration
    By max69vk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd October 2012, 16:45
  2. Dam annoying vibration!!!
    By ashmo in forum TT/TT-S/TT-RS Forum
    Last Post: 24th May 2012, 19:00
  3. Annoying vibration on the pedals
    By Neesh in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2010, 09:18
  4. Annoying vibration driving me scatty....
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2010, 14:01
  5. Annoying Horn Vibration......
    By simch in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2007, 10:13
