EM TuningChris Nott
Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By superkarl
Thread: Lateral Acceleration Sensor G200 -ESP Problem fixed :D
    Jul 2011
    57
    Add S3_DAVE on Facebook Visit S3_DAVE's Instagram Channel
    Cool Lateral Acceleration Sensor G200 -ESP Problem fixed :D
    Hi All,
    Just thought I’d create a post as I two have had the dreaded G200 lateral Speed sensor.
    I have a 2001 Facelift Audi S3 AMK Engine.
    First thing I would recommend is one of these:
    VAG DIAGNOSTIC ENGINE AIRBAG ABS SCANNER TOOL VW SEAT SKODA AUDI | eBay
    It has been a life saver and for £35 delivered it is reasonable seeing as you would take it to a garage and pay money each time. (Be warned once you have one you will constantly be plugging it in to make sure there are no hidden error codes )
    I have had this error on my car since I purchased it in April 2010 and as it would only happen on the odd occasion, so took no notice of it.
    I have read through various threads and each has had a different explanation as to what sensor goes where and the need to calibrate and not. So I just thought I would let you know about my experience.
    There are 3 sensors that are linked to the ESP:
    • · Longitudinal this is located behind the passenger glove box.
    • · YAW and Lateral this are both under the steering wheel- it looks like 1 big sensor however they are mounted on top of each other.
    The Lateral sensor is the smaller of the two.
    Please see below for the part number:
    I did try the fix (as I was trying to save £160 on a new sensor)
    BLUEVISIONS
    However the same error was coming up. So I bit the bullet and brought a new sensor. Plugged it in and using the VAG scanner (above) erased the fault and it hasn’t come up since.
    Car drives like a dream now.
    Hope this helps.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    I had the G200 issue too, bought a new sensor and it turned out that the bracket it's clipped to was bent so not sure the new sensor was actually needed!
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    lateral and longitudinal are also the same sensor.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Doesn't that depend on the year? I know some had the combo and some don't or do you mean same part number?
    Jun 2011
    S.E. Melbourne/ Australia
    146
    I do have this fault and it pops up from time to time ( ESP light remains on till next start up).
    Hate to think what would cost this sensor at local audi dealer here down under.
    2000 Brilliant Black TT Quattro.
    2010 Daytona Grey TTRS.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    Quote Originally Posted by Sam_ View Post
    yes same part. theyre just mounted differently
    Feb 2012
    bedfordshire
    755
    I got this problem again my abs and ESP light keep coming on fault code is saying longitudinal sensor but not sure where this is behind glove compartment or under my stearing wheel
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    glove box.
    you have vcds? if so you can unplug them and watch the readings for long and lat go mental to confirm which is which. thats how i worked it out
    S3_DAVE likes this.
    Jul 2011
    57
    Quote Originally Posted by Rosso TT View Post
    Audi charged me £159 with staff discount as one of my mates works for SEAT (mad when you actually see the size of it.)
    Jul 2011
    57
    glove box.
    That is how i diagnosed the issue, i used my V-GATE scanner (VAG DIAGNOSTIC ENGINE AIRBAG ABS SCANNER TOOL VW SEAT SKODA AUDI | eBay) and did exactly that scanned it, unplugged each sensor until there was no additional error and it confirmed the sensor in question.
    Feb 2012
    bedfordshire
    755
    Quote Originally Posted by David.Davey View Post
    Yeah I think it's £160 for the part, so they fitted it for free really it is a skank for what it is I am debating in getting a second hand one off ebay for around £50 and fitting it myself
    Feb 2012
    bedfordshire
    755
    glove box.
    no mate only got one of those £30 vag scanners it lets me clear the fault which is telling me its the sensor but a few days or so later it comes back then goes off again
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    mate Audi qouted me 1300$ to fix or call up awesome gti and you pay 580$ still allot but cheaper then latter
    though you should note that mine is sadly combined
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Pretty sure I got the sensor from VW (who buys parts from Audi? it's just added markup on the price) and it was $200 or so. Maybe check my thread or I can look through receipts. Piss easy to fit. Literally 15-20 minutes plus calibrating it in VCDS or a liquid gauge.
    Dec 2011
    Bridgend
    16
    Can I ask a question on the ESP as I believe I may have a similar issue.
    My (8L) 2002 A3 1.9 TDI Quattro Sport kicks in the ESP on what I describe as moderate cornering, more noticable when switching direction(fast sweeping roundabouts etc). The dash light comes on and the braking systems does its thing and tries to re-stablise the car, when to be honest it is no where near any loss of grip.
    I've run a full VCDS scan and nothing comes up with regards to fault codes.
    Need to get this sorted as it does scare me to death when committed to a corner and it takes over, I've resorted to turning it off when approaching patches of road I enjoy driving.
    Am going to have to have a look if its a badly posistioned or loosly fitted sensor, but any recommendations would be greatly recieved.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Is your steering wheel centred when driving in a striaght line or does it sit off to the left or right a bit?
    <tuffty/>
    Oct 2012
    Manchester
    9
    <tuffty/>
    Hi guys, first post in a thread that uncovers a problem that I may have haha..I have the ESP fault as well. Intrigued by the centered steering wheel as mine isn't?? But I also have no speedometer reading and Rev counter dies (VSS ordered from Audi stealers).
    Not been scanned yet but will be ordering that scanner tonight. I have numerous issues, Oh the joys!
    Only just bought my A3 and looks like I may be here a lot.
    Jan 2011
    Australia
    1,316
    <tuffty/>
    i wish i had a dollar for every time you said that Paul, might as-well record it :P
    Dec 2011
    Bridgend
    16
    <tuffty/>
    sits nicely in center. I do have a worn/split rear wishbone bush, wondering if its causing the sensors to see a step change in cars posture, hence engauging safety system?
    Nov 2012
    Where did you get the sensor from and do you have part no. as can't read it from your picture, is it 1J0 907 651A? Did you fit it yourself? Any help is much appreciated. Cheers Matt
  1. ESP and flashing glow plug icon. Lateral acceleration sensor?
    By Taff D in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2012, 18:52
  2. Replies: 10
    Last Post: 12th April 2012, 06:44
  3. Replies: 4
    Last Post: 24th March 2012, 18:24
  4. 01413 Lateral Acceleration Sensor G200
    By Badgeronimous in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2007, 15:50
  5. lateral accelerator sensor...
    By MimpiHantu in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2003, 02:07
Tags for this Thread
