Chris NottVolks Autos
Results 1 to 16 of 16
    Apr 2003
    s.wales
    363
    What spring do you use in a Forge DV007 ?
    Hi all, posted recently regarding a possible boost leak with my mapped S3. Had the front bumper off and tightened the clamps up and still the same. Out of desperation took off the turbo to i/c pipe and various brackets , made sure the pure oxygen sensor was tight, and refitted everything making doubly sure all was secure and sitting right.
    Next thing was the DV . Got the forge one , and when I originally had it , it felt weaker than the standard one. Forge gave me a yellow spring when I called them about it.
    I tried the original one back on tonight and the difference was quite noticeable. Much sronger pulling . Haven't had Vagcom on yet.
    This leads me to ask....... Should I have a blue or red spring instead of the yellow ?
    Boost is around 1.5bar.
    What spring does everybody use ?
    Chris.
    Feb 2004
    UK
    1,320
    Re: What spring do you use in a Forge DV007 ?
    I'm running a forge dv007 ,standard spring ,1.5bar,360bhp.No Problems.
    Feb 2004
    UK
    1,320
    Maybe it was a faulty actuator???
    Apr 2003
    s.wales
    363
    The actuator on the turbo ?
    Chris.
    Feb 2004
    UK
    1,320
    Yes ,what exactly is the fault?
    Apr 2003
    s.wales
    363
    There's a sound of air escaping. Gets louder as the car comes on boost. Snap the throttle shut and you can hear it stop. Thought it may be an exhaust leak, but no sign of a leak from the exhaust on idle.
    If it were a problem with the actuator it would be there with either the standard DV or the forge one .
    It definitely pulled harder with the standard valve on.
    As I said , I've checked the clamps and replaced some with the Mikalor wide band bolt type. One thing, the pipe that comes off the turbo has some splits in the inner silicone rubber but they don't go through the outer wrap. Can air escape through this wrap ? I wouldn't have thought so.
    Has anyone ever had a problem with leaky i/cs ?
    Chris.
    Feb 2004
    UK
    1,320
    Like you said sounds like a minor split in a hose,check everything around the dv ,it won't be the actuator if you can actually hear air escaping.I have a pair of s3 ic's on ebay at the moment if you do find a leaky one.Could you still hear the noise with the standard valve?
    imported_VaulterTim
    Also check your vacuum hoses... the one that feeds the DV had been worn away on a hot pipe on mine when I got the car. Same noise, hissing or noise of air escaping...
    Jun 2003
    133
    Hi s3bow
    Sounds like the DV, i had real problems with the forge 007P. Ended up getting a AMD viper, i had no further problems after the viper was installed.
    I got a refurbishment kit off forge, DV went well for about 2 days before symptoms came back. I think other people have had problems with forge DV's. IN my option they are badly designed and i wouldnt get another one.
    Apr 2003
    s.wales
    363
    Ryan, yes the noise is still there with the standard valve in place.
    I've checked the vacuum pipes and the little pipe coming off the side of the inlet manifold. Nothing. Been looking around the i/cs for signs of a leak but they are so grubby its hard to spot any signs.
    Any way of pressure testing the system. Suppose the only way of running under load and trying to find the leak is on a rolling road.
    Chris.
    Apr 2003
    s.wales
    363
    Andy, what spring did you use ?
    Chris.
    Jun 2003
    133
    I tryed using all the springs except the strongest spring(red). Didnt make any differance.
    Have u checked your brake servo hose, its a small U shaped hose next to drivers side turbo hose. I had that split took my ages to find it, you have to remove it to check it.
    Apr 2003
    s.wales
    363
    I've read about that one before. Haven't had it off but had a good look around it.
    What was the problem with your Forge DV ?
    Chris.
    imported_VaulterTim
    [ QUOTE ]
    Been looking around the i/cs for signs of a leak but they are so grubby its hard to spot any signs. Any way of pressure testing the system. Suppose the only way of running under load and trying to find the leak is on a rolling road.
    [/ QUOTE ]
    Try pouring some soapy (fairy liquid?) water on them... a leak will show bubbles.
    Just a thought...
    T
    Apr 2003
    s.wales
    363
    Just been out to the garage for another look and there's a split in the afore mentioned servo pipe. The one that does a 180 on itself. Cheers Andy !
    Chris.
    Jun 2003
    133
    Happy to be of help
    Heres the replacemeant hose u need. Think its a 13mm diameter u need. Best double checking, its been a while since i got it.
    Samco 135 hose
