Chris NottAH Fabrications
Results 1 to 15 of 15
Like Tree2Likes
  • 2 Post By Welly
Thread: N249 bypass
    Oct 2012
    35
    N249 bypass
    Hi guys
    just bought a 1999 audi a3 quattro 1.8t to run over the winter,been looking into the n249 bypass,could anyone help me with this?
    thanks
    Yohan87's Avatar
    May 2011
    404
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    There is a guide I did about 3 million years ago in the stickies. I could link it but can't be arsed...
    Westy and AudiS3-Turbo like this.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Sep 2012
    Aberdeen
    9
    Did this mod the other week with some odds and sods of hose i had lying around my shed. I only really bothered as the bracket for my vac chamber was missing and it was bugging me having it flop around on the top of my engine.
    As has been said, plenty of guides around including a couple in the stickies section. Its really fairly simple once you get stuck in.
    I liked the clear pics in this guide - GolfGTIforum.co.uk - An independent forum for Volkswagen Golf GTI enthusiasts.
    Only thing with that guide is that they T into the FPR feed which is advised against so use the other one instead.
    2001 A3 1.8T (ARY) Quattro
    Yohan87's Avatar
    May 2011
    404
    Can the N249 valve be mapped out? I've just left mine connected in at the moment to keep the ECU happy.
    slappy_dunbar's Avatar
    Let's Do This
    Westchester Cty, New York USA
    227
    ​Beware this mod. With the N249 gone you lose a lot of refinement in the pedal response. The car will feel jerky and hard to drive smoothly. You'll find yourself apologizing to passengers a lot.
    Yohan87's Avatar
    May 2011
    404
    Quote Originally Posted by slappy_dunbar View Post
    You sure about that?
    Mine is silky smooth, but could be down to the mapping?
    Sep 2012
    Aberdeen
    9
    I had read some people mentioning some jerkiness whilst reading up on it but personally i didnt notice any difference before or after. (bog standard car)
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,504
    It sharpens the response to the dv. I've had mine done and no jerkiness! Did you leave it electronically connected? You can remove the valve but you'll need a resistor of some sort (it's in the sticky welly provided).
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,316
    tried this on mine but didnt work left me with a flutter valve, checked all pipes and connections and was all right but didnt work for some reason but as others have said it did feel worse without it.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,504
    You want to check the pipes to the DV. Have you made sure that youve kept it connected and you havnt broken the n112 valve?
    Syvo's Avatar
    Jan 2011
    warrington
    1,316
    sure did m8 checked everything twice even took it to local garage and they said it was all connected fine so just put it back to normal and kept the silicone pipes and been all fine
    WillJP's Avatar
    Dec 2011
    Portsmouth
    32
    I did mine the other day, it's pretty simple. Didn't really change much as in jerkyness? I put a resistor in the plug
    I dont know if it's just me but the dv sounds a little louder?..
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    996
    Quote Originally Posted by Syvo View Post
    I think paradox1 sorted it out mate (post 61):
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/122962-n249-bypass-guide-ary-engine-all-other-a3-engines-2.html
    I just cant work out what he did....lol
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Syvo's Avatar
    Jan 2011
    warrington
    1,316
    me neither it all looks the same as they way i originally did it, will just leave it not causing any problems if it aint broke dont fix it.
  1. N249 Bypass How To (2000 S3 - but same for many)
    By Welly in forum General Technical / How To
    Last Post: 9 Hours Ago, 20:41
  2. N249 bypass
    By cawsey20 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2010, 22:47
  3. N249 Bypass on 2003 s3
    By drewlad in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th April 2010, 09:09
  4. N249 Bypass/Removal
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2010, 15:11
  5. Vagcom results after N249 bypass and reversed DV
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2009, 11:03
