Chris NottVolks Autos
Results 1 to 20 of 20
    Feb 2012
    23
    Question Strange noise from the rear at low speed when turning
    I've had my S3 8L since February and it hasn't missed a beat (flew through its mot a couple of weeks ago too )
    Today I noticed a strange noise when I was in a car park turning.
    Basically there is a vibrating/rubbing (almost like the handbrake has been left on) sound coming form the rear of the car when turning.
    The noise doesn't appear to be there when going in a straight line or at speed.
    I have jacked both sides up at the rear and wiggled the wheel/checked for any play and they seem ok (i.e. no wheel bearing issue).
    Nothing appears to be hanging off back there!
    The springs look in good condition, as do the CV boots.
    The wheels rotate freely with the handbrake off and lock with it on as they should.
    Does anybody have any ideas what it could be?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    819
    Add Vex182 on Facebook
    Could be the haldex dragging, is the 4wd system working?
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Feb 2012
    23
    I'm not sure, how do I check that it is or not?
    I tried turning off the ESP as I read something about the haldex, but it doesn't change the noise at all?
    Vex182's Avatar
    Apr 2012
    Hinckley
    819
    Best way I found was ESP off, find somewhere where your rear wheels are on grass and give it a sharp pull away, when I peer out my door I can see the rears wheel spin. Others can probably give another way to test it.
    Feb 2012
    23
    I've read about removing the haldex fuse to see if the noise stops at all?
    The car has been well looked after and the haldex was serviced not long before I bought the car earlier this year.
    I also read about possible CV issues? I thought these 'clicked' rather than vibrate/grind/rubbing type noise though so starting to think the worst...
    Sep 2012
    Walsall
    9
    The mrs had a similar problem with her old 1.8T A3, it turned out to be the rear caliper sliders sticking, Audi sorted it under warranty
    I remember going out on a rd test with an Audi tech, at slow speed he pulled the handbrake & it stopped
    Worth a try, you never no
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,171
    Is it only noticeable at very low speeds (ie 5mph)? It may be that above this you can't hear it due to road/wind noise.
    Some questions
    - can you hear it on the outside of the car (ie wind the window down and listen carefully)?
    - is it the same on left and right turns?
    - nothing at all in a straight line at the same speed?
    From what you describe, it sounds like it's more diff-related than Haldex-related to me. If it only does it when turning and is the same in either direction then that points to the diff operation. I'd try draining the oil out of the rear diff and replacing it with fresh. Easy to do, see the link below:
    HELP: Rear diff oil quantity
    In terms of the Haldex, if this was the problem then you'd hear it whether you're going straight or turning. If you want to check it's working, wait until it's raining and turn your ESP off. Then pull away sharply from a standing start on a wet road. Now repeat with fuse 31 removed or the handbrake pulled up ONE notch (to disable the Haldex). You'll find you get s**t loads of front wheelspin with the fuse removed/handbrake up ONE notch compared to with it plugged in!
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    That is very symptomatic of a Haldex service being required.
    Either get the kit and do it yourself, or get it to a garage for a Haldex oil and filter change.
    I would bet a LOT of money that the problem will be gone afterwards.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by The Doctor View Post
    Whilst the logic is sound Doc, the Haldex is a weird one. Haldex systems complaining about oil only ever grumble when low speed turning.
    Mine did exactly this, as did a mates. Haldex service on both and both problems went.
    Homer Simpson
    Aug 2011
    Plymouth
    597
    Add Lavis89 on Facebook
    i've had this problem for AGES. taken it to a couple garages and had no luck so far. might have to take it to an audi specialist and try out a haldex service, it hurts me hearing a horrid grinding noise every time i turn at slow speed.
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    Erf
    Oct 2006
    Kingston
    230
    Take fuse 31 out. If it the noise goes away, you have a haldex issue.
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,171
    Hmm, don't understand how this would be Haldex related, but if you've solved it with an oil & filter change Welly, then of course I believe you.
    Really easy to do yourself if you have axle stands:
    Haldex Oil and Filter Change - How To.
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Erf View Post
    Not necessarily. You should be changing the Haldex oil and filter every 40K at least anyway. Audi don't recommend doing it for a bit of a laugh.
    Homer Simpson
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    I know it sounds odd, but it's true. I didn't think it would make any difference either Doc, but it does. Old Haldex oil just seems to cause groaning from the diff area.
    Homer Simpson
    Feb 2012
    23
    Hi guys, thanks for all the advice.
    I am pretty hands on when it comes to my cars, but this is the first one I have had with a haldex 4WD system.
    The noise appeared to disappear yesterday, however I am not 100% happy as it can't have just happened and fixed itself!
    I had the wheels off last night, checked over the brakes/CV's/Wheel bearings etc and couldn't find anything wrong.
    I spoke with my cousin (who has had a few 4WD audis) and he also recommended a Haldex service as it only does it a low speed and turning.
    My car had the Haldex serviced last year at around 78K. I bought it earlier this year and the car is now about 95k, so I will change the haldex oil and see if anything changes. Where is the best place to get the proper oil from (I don't like my local audi stealer by the way...)
    Reesy's Avatar
    King of the Mods. Apparently.
    East Sussex
    3,600
    Visit Reesy's Instagram Channel
    Quote Originally Posted by 86fran View Post
    Go to the next closest one then..
    Or TPS
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,171
    Or you could order it online. Do the filter while you're at it, and get the filter removal tool because you'll need it.
    Feb 2012
    23
    Thanks,
    Is eBay the easiest place to get the tool/oil/filter? I'm going to be out of the country for the week so need to order it online.
    Jan 2013
    I have a very similar problem with a transmission wind up at parking speed while using lots of lock. Haldex oil and filter changed, diff oil all new and clean, all brakes free and driveshafts ok! Vag com checked for code's and nothing in it. Now I'm lost where to check. Did you solve ur problem and if so what was it? Also as snowy at the moment rear drive is certainly working.
    Steven.c's Avatar
    Auto-Motive Restored Deatail
    Sep 2011
    Shropshire - West mids
    282
    i used to have this problem on my A3 1.8t FWD, turned out it was my middle section viberating on the car because it has that hanger thats really strange and seems to hit the bracket. only done it at low speeds and when turning left :S worth a look at mate.
    Metallic Ming Blue a3 1.8t sport.
    K03s, Revo stage 1, Jetex(JR) filter, Silicone TIP,N249 Bypass, Forge Split-r'seee
    Mk3 GTI Project - < Click me
  1. sort of droning noise from the rear end.
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th January 2012, 22:08
  2. Strange noise from the cabin heater blower
    By brads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2011, 19:57
  3. strange noise coming from the rear of the car (S3)
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2010, 14:09
  4. noise from the rear of my car.
    By millsyd in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2006, 21:37
  5. Strange noises from the engine
    By tfox in forum Diesel forum
    Last Post: 5th June 2006, 12:14
