Damped Flywheel
P
purple8
Just in process of replacing clutch on a 1.9tdi asv. It has a damped clutch. NEver seen one of these. You can turn the damped part slightly before the flyhweel engages . Is this right. There is a slight bit of play when passed. Again is this normal or do I need a new flywheel.
Small amounts of play in the flywheel on a dual mass flywheel is normal, if it moves a lot then replace would be my advice.
It's normally hot spots that are the thing to look out for.
Thanks. It's damped flywheel not dual mass does that make much did. the clutch looks ok. It wasnt dis engaging. But hydraulic all seemed ok. It actually turns very slightly before engaging to fully.
11
987
590
2K
418
