Results 1 to 11 of 11
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    527
    VCDS Log Check - is it running OK
    Did a 4th gear log today whilst I had my laptop with me.
    I understand some of figures but could someone tell me if this log looks OK, should I be worried about anything.
    Appreciate the help, or if I need to run more logs with different groups do please let me know.
    Group A: '003 Group B: '115 Group C: '118
    Engine Speed Mass Air Flow Throttle Valve Angle Ignition Engine Speed Engine Load Boost Pressure Boost Pressure Engine Speed Intake Air Boost Pressure Boost Pressure
    TIME (G28) Sensor (G70) Timing Angle TIME (G28) (specified) (actual) TIME (G28) Temperature (G42) Control (N75) (actual)
    Marker STAMP /min g/s % °BTDC STAMP /min % mbar mbar STAMP /min °C % mbar
    0.32 2320 5.36 5.1 0 0.62 2360 54.9 1580 960 0.02 2360 24 0 1000
    1.21 2440 51.69 99.6 22.5 1.51 2520 118 2250 1310 0.92 2360 24 100 1040
    2.12 2680 85.11 100 16.5 2.43 2800 172.9 2450 1880 1.82 2600 21 100 1480
    3.02 3040 146.53 99.6 7.5 3.33 3240 191.7 2550 2540 2.73 2880 19 100 2150
    3.93 3520 157.39 100 9 4.24 3640 191.7 2550 2540 3.63 3360 18 92.5 2540
    4.84 3920 167.69 100 9.8 5.14 4080 191.7 2540 2470 4.54 3800 18 91.8 2540
    5.74 4320 175.86 100 10.5 6.05 4440 191.7 2510 2360 5.44 4200 18 92.5 2460
    6.65 4680 181.97 100 12 6.95 4800 191.7 2480 2250 6.35 4600 21 93.7 2320
    7.56 5000 184.11 100 12.8 7.86 5080 191.7 2470 2200 7.25 4880 23 90.2 2210
    8.46 5320 197.53 99.2 18.8 8.76 5400 190.2 2500 2190 8.16 5240 24 96.5 2220
    9.36 5600 197.42 99.6 18 9.67 5680 188 2530 2080 9.06 5520 26 100 2190
    10.27 5880 201.89 100 19.5 10.57 5960 177.4 2550 2090 9.98 5800 27 100 2130
    11.18 6120 203.19 100 19.5 11.47 6200 172.2 2540 2080 10.87 6040 30 100 2030
    12.08 6320 205.19 100 20.3 12.39 6400 168.4 2550 2090 11.78 6240 32 97.6 2060
    12.99 6520 210.53 100 21.8 13.3 6560 161.7 2540 2170 12.69 6440 33 95.7 2080
    13.89 6680 206.19 99.6 21 14.21 6720 157.9 2520 2110 13.6 6640 35 95.3 2090
    14.81 6840 207.86 100 21.8 15.12 6880 157.1 2520 2090 14.5 6800 36 95.3 2110
    15.71 7000 211.22 100 22.5 16 7000 148.1 1950 2030 15.41 6920 38 95.3 2120
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    looks good to me.
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    but it quite a bit short of requested boost? n75 is 100%.. is that n75 duty cycle?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    527
    Quote Originally Posted by Alex C View Post
    I noticed that from 5000rpm upwards, does this mean a tired turbo?
    [8L BLOG] [8P BLOG]
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    it manages to make 2540mbar at 3640rpm but not at over 5000rpm. maybe a tired turbo
    Alex S3 AMK
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    527
    Any other ideas or advice would be appreciated.
    [8L BLOG] [8P BLOG]
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    looks normal to me
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    821
    Add Vex182 on Facebook
    Maybe the request is just being a bit unrelastic, after all if it was just meeting boost then you would not be getting as much out of it as you wanted, this way I guess it's making as much as it can.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    the request is high... map asking for all of it..
    bill@badger5.co.uk
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    527
    Thanks for the information, you have put my mind at rest.
    [8L BLOG] [8P BLOG]
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    you have of course not logged fueling... 031 if on wideband ecu... have a check.
    bill@badger5.co.uk
  1. Help with vcds and checking aircon
    By markie A3 in forum Air Conditioning
    Last Post: 8th April 2011, 22:00
  2. VCDS logging suggestions on what to log.
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2011, 16:02
  3. VCDS log - Take a look?
    By Stanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2011, 21:24
  4. MAF and Boost VCDS Logs, what to you think of mine?
    By ben_turbo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2010, 15:17
  5. Log checking please
    By s3_kev in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th November 2009, 22:41
