Karl,
you've got a point
... despite the whining, I still enjoy it when it, especially when it works.
Any how, started fine, engine light was on, but I did drive it for a few metres without the maf or any lambda sensors a few hours ago.
Cleared the codes and went out for a drive.
Just to re-iterate. My S3 has been off the road for 3 weeks. Since then it has had a Apexi intercooler, B5 tip and a relentless DP and sports cat.
Well, it works fine
, turbo spools up a lot sooner and it or the tip makes a sucking sound around 3000 rpm. The midrange torque starts earlier and is sustained for a lot longer.
IAT were 7 degrees, even after pottering around town, but ambient is 5.5 degrees and it is chucking it down.
The pull tapers off about 6k. I think the map needs to be tweaked.
Haven't checked for exhaust leaks yet, way too wet out there, but it does sound louder than standard.
I'm considering a madmax dv, as it seems to allow the turbo to recover a lot quicker than the stock and 007 dvs.
I took logs too, I'll upload them later.
So
to all those who have helped me get this far, couldn't done it without you guys.
Having said that if I hadn't come across this forum and your build threads, I wouldn't have gone much further than a 007 dv and a remap, so it's (collectively)all your fault
