EM TuningAH Fabrications
Results 1 to 23 of 23
    Sep 2012
    23
    HELP! a3 1.8t (agu) misfire
    This problem started after i was driving hard when the car was warm but now its doing it more or less all the time now. Its like a boost leak but its not because i have checked. Changed spark plugs a few times, new maf sensor, new ignition amp, new fuel filter, n75 bypass and its still there. Havent changed coilpacks because i have heard there reliable on the agu engines. Some one help please. Got told by a audi specialist near me it could be the flywheel??
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,639
    I would do the throttle body next as its cheap to clean and then readapt it
    Sep 2012
    23
    Already been done. Forgot to mention that. Sorry
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,906
    Visit 16Klappe's Instagram Channel
    If you have done all of that the next thing to check is the connections and loom for the coil packs. We had this problem with Prawns A3 a few years back, changed plugs, tried mafs and did loads of work looking for it. Turns out the coil loom was split from heat and wear and was shorting on the cam cover.
    Have you vag-com'd it yet?
    I quite often say I'm going to do things.
    Then never do them.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,639
    Quote Originally Posted by kev peacham View Post
    Oh right,I would clean the injectors next and look at the leads as mentioned
    Sep 2012
    23
    I have had it on vag com at the audi specialist and nothing came up. I will have a look at coil loom as its in shop for this problem on thursday and if i can solve it it will save me a nice bit of ££££
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    You can buy loom replacement kits from Awesome GTI I think.
    Then never do them.
    Oke Phill's Avatar
    Mar 2012
    147
    Does it do it on full throttle?
    Sep 2012
    23
    It is on full throttle when it happens. If i just build it up on the accelorater its ok
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    I would defo look at coil packs in one way or another; that's exactly what Prawns did when the loom split.
    Try driving it from stone cold and see if it is fine then.
    Then never do them.
    Sep 2012
    23
    Change coilpacks or check loom do you mean
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    Check the loom for any splits or cracked wires, if there are any then undo the insulsting tape to expose the wires and insulate any cracks and then retape the entire loom. Check the earths too.
    Then never do them.
    Sep 2012
    23
    Ill check that tonight and write back later with the outcome. Thanks
    Oke Phill's Avatar
    Mar 2012
    147
    My money is on coil packs, autho still check your wiring.
    If you have got the standard coil packs, ditch them for tfsi ones. I had a night mare with the standard packs failing and creating the exact same issue as you are getting. Awesome sell the tfsi coils and adaptor plates, and they are cheapest as well.
    There are many threads about the tfsi packs on here as well, have a look and see what you think, i found Tufftys build thread very usefull for this up grade.
    Thanks Phill
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    Quote Originally Posted by Oke Phill View Post
    Thanks Phill
    AGU has boltdown coils and an ignition amp so you would have to do an ICM delete to use push down coils...
    <tuffty/>
    Sep 2012
    23
    Might be sounding a bit thick here but whats icm delete? Just checked coilpack wires and they seem to be fine. (head scratching)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    Its a modification that removes the ignition control module (ICM, unit stuck to the side of the airbox) and allows you to run later bolt down or push down coil packs that have built in ignition amps and provide a better spark...
    All the A4 boys wobble on about in the good ol' US of A...
    <tuffty/>
    Sep 2012
    23
    How would i go about doing that then?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    Google would be a start ;P
    ...a few of the A4 (B5) members have also done this but 'ICM delete' in google will set you in the right direction..
    <tuffty/>
    Sep 2012
    23
    Just to let u all know got my car back today amd they diagnosed the problem as been a block off pipe on the n75 valve needed putting onto the intercooler pipe as my waste gate wasnt doing anything. Put the pipe on now and you can see the waste gate opening and closing on throttle. Still need to test it with the engine under load tho. Thanks for all your help guys
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,064
    Was the pipe missing or broke?
    Sep 2012
    23
    Neither i just didnt connect it because i didnt think it would matter when i fitted my fmic
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,064
  1. HELP oil leak ?? 98 agu 1.8t ???oil filter housing or oil cooler??
    By ScottScodude30 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2012, 15:41
  2. 1.8T AGU MISFIRE ONLY ON CYLINDER 1 !!!!!
    By dandos in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2011, 17:16
  3. Replies: 31
    Last Post: 26th February 2010, 13:14
  4. HELP NEEDED! - Flat Spot/Hesitation/Misfire
    By jdp1962 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th March 2007, 07:11
  5. Help, engine feels like it's misfiring
    By imported_spuddie007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2006, 12:41
