Chris NottBadger5
    Sep 2012
    Bedford
    19
    Clunking noise when coming off the throttle
    Hi
    have a 2000 a3 1.8t and when taking my foot off the gas get a sort of clunking noise coming from somewhere. It's not very loud and doesn't happen all the time. Usually happens driving a bit harder. Just a bit annoying.
    Any ideas what it could be?
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Have you checked the engine mounts?
    Mine made a bit of a clunk when it had a broken engine mount - but I also had a million worn suspension bushes etc. so I replaced them all. Worth having them all the suspension bushes checked over too.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Oct 2012
    i have the same problem with my 99 1.8t, when i let go of clutch and have throttle i hear like a faint metallic clang, never bothered me though and only seems to be in 2nd and 3rd gear
    May 2012
    RETFORD, NOTTS
    1,753
    Quote Originally Posted by kam666 View Post
    Dodgy clutch pressure plate? i had an astra mk3 tdi that did this, it got worse, felt like a sticky clutch cable, and when i replaced it there were 4-5 fingers missing from the plate.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Sep 2012
    Bedford
    19
    Yeah thats exactly what happens with mine. I'll check the engine mounts, seems like a better fix than turn my stereo up till I can't hear the noise anymore.
    Thanks for the replies
  1. 'Click' when lifting off the throttle
    By ADi Nuff Valves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2011, 15:11
  2. Worrying noise when coming off a roundabout under acceleration,
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2011, 14:56
  3. will the N75h valve cause over reving when i come off the throttle?
    By feville in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2010, 17:17
  4. Fluttering noise when lifting off accelarator
    By imported_alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2005, 11:51
  5. strange noise when you open the drivers side door
    By MateloT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2004, 13:30
