EM TuningVolks Autos
Like Tree1Likes
  • 1 Post By sandwich1987
Thread: Wmi
    Sep 2011
    Scotland Dumbarton
    246
    Wmi
    Is there a way to test my install to see if I've wired everything correctly without actually driving the car?
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    More info would help mate.....what kit you got, how is it installed, possibly any paricular ways its wired up and activated?
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Sep 2011
    Scotland Dumbarton
    246
    It's a devilsown stage 1 kit, trying to think of a way to trigger the boost switch without actually putting boost through it lol, I'm sure I've gt it wired up correctly up until the connections under the steering wheel, I've used the terminal 75x as I've read that's the switched live, and I've took a permanent live from the terminal next to that.
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,901
    Re: Wmi
    If you have a boost switch on the kit that you have set for the wmi to kick in, there should be a test setting on it, I think.
    There was on mine, I have a cooling mist deluxe kit.
    You could also give it a google if you already havn't
    k03s/k04 hybrid a3 275bhp 293lbft
    vr6 mk2 golf gti
    fellow north east members add your name to this list.
    http://www.audi-sport.net/vb/north-e...%2A%2A%2A.html
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Sorry i'm not familiar with the devils own stuff
    I know the aem kit has a test button on the controller, if the kit is a simple on/off where the boost pressure switch is concerned then may be able to link the switch out to frigg/test it but wouldn't reconmend it unless you really know what your doing and have got a meter to confirm otherwise you could very easily break things
    If not best bet is to take it for a drive and mark how much fluid is in the tank or could always have a friend to help you and hold the nozzle to confirm its spraying
    Sep 2011
    Scotland Dumbarton
    246
    Managed to test it there just took the terminal off the no contact and touched the nc terminal and it worked, was without the nozzle when i tested it so I got a bit wet lol
    coatesy likes this.
  1. Throttle body spacer with wmi port
    By Dannyc87 in forum Backdraft Motorsport
    Last Post: 14th May 2012, 11:02
  2. AEM WMI .....Check valve fault...again..
    By s3dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2012, 15:46
  3. WMI and Throttle Bodies - Possible but unconfirmed effects.
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2011, 11:53
  4. Erl WMI... How good?
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st October 2011, 16:46
  5. Thinking about WMI... Just a few little questions
    Last Post: 9th July 2011, 12:17
