EM TuningMonster Motorsport
    Oct 2012
    Softcoding for Central Locking
    Hi,
    I've just picked up a cheap 51 plate A3 130tdi.
    The car came with 2x keys with a light button, but no radio function. I believe anything after 1997/1998 should have a CL pump that supports RCL, so I'd guess that a previous owner had lost or broke their flip key, as one wasn't supplied.
    Could someone confirm that ALL 2001+ models should have RCL.
    Secondly, I've searched on this forum and found a file that shows the softcoding options for the central locking, however the link is dead. Does anybody have the below file, that they could send me? Just incase I need to turn this funciton on, in the event it wasn't dealer-activated
    A3 2000+
    http://www.robvanguard.co.uk/a3/CODING00.pdf
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi
    From what I remember you can make the ECU learn a new open/close remote by putting a valid key in the ignition and press some buttons on the new remote fob. I did this on my old A3 (98 model) with the two button remotes.
    But that's only for opening/closing the car- which is what you're after.
    Perhaps then you can get a cheap/stolen/lost/pilfered remote off ebay and swap the key blade and RFID transponder?!
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  1. Central locking pump keeps buzzing for a bit after opening
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2011, 20:54
  2. Wiring diagram for 1997 A4 Central Locking Pump?
    By clfletch in forum General Technical / How To
    Last Post: 4th April 2007, 21:27
  3. Where to fit Central Locking for a Mk IV Golf?
    By sjmills in forum Volkswagen and other VAG
    Last Post: 7th November 2004, 09:56
  4. Remote central locking kit from Vagparts.com
    By cloggs in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th May 2004, 17:58
  5. HELP!!!!! Central locking not working.
    By howard in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2004, 08:57
