Sky InsuranceJMB Retrofits
    Sep 2012
    Colchester
    90
    Heat-wrap / ceramic coat on manifold
    I did a search but didnt find anything, so sorry if this has been posted before....
    Ive contacted Sam via facebook in regards to getting a v3 relentless downpipe and sports cat, But im thinking maybe getting a manifold at the same time. Saves messing about behind the engine twice if i discover the standard is close to throwing in the towel!
    Does everyone heat wrap / ceramic coat thier manifolds or just leave as is? Fancy reducing some of these under bonnet temps a little before i start working on the induction side.
    I know its going to create a risk in raising the temps of the turbo...which ive read the k04 doesnt like, but im not planning on doing too much performance wise anyway............... Famous last words....!
    I just want to improve a few things and reduce the lag. Which is why im planning FMIC.
    phil miller's Avatar
    Sep 2012
    Devon
    843
    hello mate well ive seen this come up a few times and most people add plenty of heat shields rather than wrap the exhaust, cheaper and less harmful for the heat build up around the Turbo
    RIP S3dave
    May 2004
    nr Glos
    7,153
    decent ceramic coating will cost as much as the manifold.. Zircotec high performance coatings, ceramic coatings, engine, automotive, motorsport, exhaust manifold and header coatings. for example
    excellent coating but dear
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  1. Heat wrap.....
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2011, 22:40
  2. Red hose from turbo to inlet pipe.... should it have heat wrap???!!!
    By AWDMk1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2010, 06:25
  3. Intake Heat Wrap- About to commence..is it worth covering the fuel lines?
    By akash_sky1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2010, 23:21
  4. Heat Wrapped OEM Box and Maf?
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 14:07
  5. Heat wrap on down pipe?
    By BOSSS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2010, 10:02
