EM TuningBadger5
Results 1 to 12 of 12
    Sep 2012
    bournemouth
    32
    Road/rolling road haldex problem??
    Audi s3 amk
    took my car for first dyno run today as i been having a strange problem almost as if it was losing boost then gaining boost and loosing it again.
    Can be driving down the dual carriage way and when putting your foot down you can feel it kick in and out several times before it will eventually let you go up the rev range. On the 4 wheel drive rolling road you could see where it was cutting in and out. Its getting full power for a standard s3 with 216.7bhp at the flywheel.
    When the fuse was taken out for the haldex and rolling road set up for 2wd it was perfectly fine straight up the rev range
    has anyone come across this or anybody got any ideas???
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    When was the haldex last servicedkthink that may be at fault
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    RIP S3dave
    May 2004
    nr Glos
    7,199
    a lot of 4wd dynos will also show this apparent stepping.... Be sure its not that instead throwing a wobbler.. red herring so to speak
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Sep 2012
    bournemouth
    32
    well i have had it on occasions when its happened on the road for example putting my foot down to over take someone
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Cant you pull a fuse to make them fwd?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Scanned for faults?
    <tuffty/>
    Sep 2012
    bournemouth
    32
    Only just got back from the run is the haldex system scannable as a seperate item with snap on scanner
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Quote Originally Posted by possyoo View Post
    No idea which is why VCDS (even VCDS lite) is a better option all round...
    <tuffty/>
    phil miller's Avatar
    Sep 2012
    Devon
    843
    if its an up to date snap on scan tool then yes you should be able to, although VCDS will be 1000 times better, the snap on unit is k for most stuff and IMHO is perfect for the delete it kids (you know the tyre shops that just delete the code and charge you £30) anything more really to beyond it imho
    sam4191's Avatar
    If In doubt, Flat out!
    Feb 2009
    Highcliffe, Dorset
    399
    Scrap me thinks...
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,084
    Visit 16Klappe's Instagram Channel
    I had a problem with a lad called Rob or Ryan (I think) off here with an MTM S3, his car was sometimes boosting low and would feel like the esp was kicking in and causing the car to lose boost and then it would go back to full boost and go like ****. It wasn't causing the esp light to come up on the dash and it wasn't showing any fault codes.
    Anyway, we inspected the fuse box above the battery and it was all oxidised, I cleaned the holders terminals on the fuse tray and put a new fuse in it and job done. Have a look to check if it isn't covered in crud or the casing melted.
    A lot of people hear hooves and think of zebras. It might turn out to be something as simple as that, it's free to check so give it a go.
    That said boost fluctuation is usually a boost leak.
    I quite often say I'm going to do things.
    Then never do them.
    Jun 2011
    S.E. Melbourne/ Australia
    146
    Hi possyoo, is your graph similat to this?
    Odd behaviour on the rollers
    2000 Brilliant Black TT Quattro.
    2010 Daytona Grey TTRS.
  1. Replies: 3
    Last Post: 10th October 2011, 08:52
  2. DSG problems on a rolling road
    By miketweed in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd February 2006, 17:57
  3. haldex and rolling road?
    By marckell in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2005, 19:51
  4. Detecting problems using Rolling Road
    By imported_gek in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2004, 20:01
  5. Rolling road problems
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2003, 18:52
