Monster MotorsportEM Tuning
Results 1 to 12 of 12
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Which injectors for upgrade and when to install?
    I'm in the slow progress of getting parts ready for next stage of upgrades.
    I currently have
    Miltek cat back
    Relentless mani, downpipe & 200 cell cat (getting fitted soon)
    Revo map
    B5 Tip with heat shield and JR Filter
    Forge 008 DV
    IE rifle drilled rods (not yet fitted)
    AH fabs fmic.
    I am thinking of going down the hybrid route as not chasing massive bhp figures. Just trying to uprate on a tight budget
    So to spread the cost I'm picking parts up as and when.
    So basically I would like to know which injectors are suitable so I can keep my eye out for bargains.
    I have searched a bit on here and the popular choice is Bosch 550cc
    Can anyone tell me any cars these are standard fit on or alternatives?
    And finally am I right in thinking these are not to be fitted until hybrid and custom map is done or can they be fit sooner and ecu will adapt itself for them?
    Thanks.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    550s.
    only fit on the day of mapping, at the tuners
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    I use genesis ones...and they are fantastic with my stage 3 hybrid.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Is it best to stick to 550 or go bigger and have map set up to suit so they are under less load.
    2001 S3 (AMK)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,584
    550cc Bosch EV14's but no need to fit them unless your spec is as high as Westy's or you have a hybrid... std S3 injectors max out around the 280hp mark with a little head room... if going hybrid then you will need to leave N75 electrically unplugged and injectors off and leave it to the tuner to fit...
    ECU will adapt out fuelling excess from the 550's but it will not be ideal so best not to fit them at all until the car is parked at the tuners..
    <tuffty/>
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Are the Bosch 550 just an aftermarket option or are they standard fit on other cars?
    Still gotta research hybrids some more yet. But no doubt a search will reveal loads.
    2001 S3 (AMK)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,584
    Not sure what they are fitted too... 550's are plenty for a hybrid and the Bosch EV14's have a very good spray pattern and atomisation so work very well... proven in many installs and plenty of maps tuned to run them so known setup data...
    Other injectors are available but would take longer to map in perfect...
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    The Genesis 550s are an option too and are very good..
    Jimgrim77's Avatar
    Nov 2011
    957
    Oh yes...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,584
    Bosch EV14's are supposed to have a better spray pattern than genesis ones... Bosch are a more up to date and mdern injector.. genesis have been around a while... unless you get them for a barg price I would stick to the bosch personally
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    <tuffty/>
    They are exactly the same injector just marketed in another name....
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Thank you all. Time to start searching for sellers now.
    2001 S3 (AMK)
  1. Which led bulbs for interior and number plate lights?
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th June 2010, 09:20
  2. Which injectors for TDi
    By Pat J in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2010, 12:13
  3. Which injectors and fuel pump for 380 bhp
    By Paul_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2010, 19:32
  4. Taptalk now installed for Iphone and android devies
    By Administrators in forum Site Support & Announcements
    Last Post: 14th January 2010, 19:27
  5. Replies: 44
    Last Post: 28th November 2009, 19:53
