Sky InsuranceAH Fabrications
    Jul 2010
    A3 - 8L door panel removal
    Hey there,
    Kindly help with some pics to show where I need to get into to remove my front door panel to get to the speakers.. just cant seems to find the holding clips or screws!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    There are two screws at the top... one at the front of the door and one at the back (black with a screw cup)... then look at the door handle... there is one screw holding on a black cover (inside the handle facing to the back), remove this cover and undo the two screws behind it...
    Lift the whole door panel up then tilt back... everything should be obvious...
    <tuffty/>
    May 2012
    RETFORD, NOTTS
    1,706
    Link provided to me by AndyMac
    http://freepdfhosting.com/e4b607e6d8.pdf
    Jul 2010
    thanks guys, the link should help too.. will try it out asap..
  1. Audi A3 2009 Door panel removal???
    By Asyddall55 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2012, 15:30
  2. remove front door panel
    By livlee1 in forum General Technical / How To
    Last Post: 13th February 2007, 07:37
  3. Removing door panel
    By Caesium in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th August 2006, 00:20
  4. A4 B6 door panel removal - help!
    By imported_Pottsy in forum In-Car Entertainment
    Last Post: 24th October 2004, 17:29
  5. Removing Front Door panels and rear panels
    By imported_officedog in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2004, 19:36
