Sky InsuranceAH Fabrications
    ap
    Jul 2010
    Northamptonshire
    37
    Wheel bolt questions
    Hello a quick 2 questions for you knowledgeable people.
    I hear that after market wheel bolts have a different tapered interface than that of Oem wheel bolts, does anyone have an image of the differences or point me in the direction of a website that could illustrate this to me?
    secondly, dimensionally how much thread should be holding the wheel on if you where to poke the wheel bolt through the wheel and measure how much of the bolt is exposed from the back of the wheel to the end of the bolt?
    thank you in advance your help, as always is much appreciated
    Andy
    Feb 2006
    Lincolnshire
    691
    OEM bolts are what's called radius, or curved, and most aftermarket bolts use tapered shoulders, almost like two sides of a triangle.
    My text drawing skills are weak, but almost like;
    [)== Radius
    [>== Tapered
    As for how much thread should be sticking out the back of a given wheel, it will depend on the wheel design. A good rule of thumb though is that you should be able to get 5 or 6 turns of the bolt before tight, which will get a 1.5mm pitch thread bolt 8 or 9mm into the hub. I wouldn't want any less, but you have to be careful you don't go too long either.
    Audi S3 - 2002MY - Denim Blue
  1. Wheel bolts - potentially stupid question!
    By dalespitfire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th January 2010, 20:36
  2. Quick wheel bolt question...
    By PNH80 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd August 2008, 17:46
  3. Alloy Wheel Bolts?
    By imported_Rooney in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2004, 00:45
  4. Rounded one of my locking wheel bolts off
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2004, 14:57
  5. Locking Wheel Bolts
    By ScottyKemp in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2004, 12:42
