Monster MotorsportVolks Autos
Results 1 to 13 of 13
    Dec 2011
    Bedfordshire
    127
    Mk1 s3 temperature
    I have recently bought a audi mk1 s3 it's been well looked after and has a full service history and when warmed up it sits nicely
    at. 90 degrees and when I'm driving along it drops to 80 but now it's got a bit colder I was driving today at 60-70 ish in 6th gear around 2000 rpm and it was around 5degrees outside and the temp dropped to 60 is this normal?as I also have a mk1 Audi a3 1.8tand that sits at 90 constantly when warm
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Nope, should always be a solid 90 no matter what. Its either the cts or thermostat. The cts is the easiest to change bit the dearest, try that, if not then its the thermostat.
    Dec 2011
    Bedfordshire
    127
    Thanks for that what is a cts? I'm new to all this
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Coolant temp sensor mate, its between the block and the battery in the plastic housing that feeds the block coolant.
    Dec 2011
    Bedfordshire
    127
    Ok cheers mate
    Oct 2012
    Cardiff
    12
    Yeah, i had the same issue, i changed the Coolant temperature sensor and sorted it!
    1 month later and it started to overheat, ended up being my water pump! Hope you have better luck with temperatures than i did!
    Dec 2011
    Bedfordshire
    127
    Quote Originally Posted by GhazS3 View Post
    I hope so too!! It just had Cam belt and water pump before I bought it so should be ok thanks for the help
    JNP
    JNP's Avatar
    Jan 2011
    Basingstoke
    102
    Sorry to hijack the thread jay.
    Dani, is it not normal for the temp to be at 80 deg while your going down the motorway? Mine sits there until i slow down and then goes to 90?
    Sensor fault?
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    453
    Nope. Should always be a rock steady 90. Whether you are hooning it or sat in traffic.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Nope, as said, should always be at 90 mate.
    JNP
    JNP's Avatar
    Jan 2011
    Basingstoke
    102
    OK cheers guys, can I just get away with a bog standard one off Ebay AUDI COOLANT TEMP TEMPERATURE SENSOR 059919501A SENDER A2 A3 A4 A6 A8 TT TTS S3 | eBay or do you reccomend going OEM? (Bit worried about buying a part off Ebay for the car which is only £7 lol)
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    Try using the climate panel to display the reading, see if it differs from the gauge.
    If it gets up to temp when sat in traffic and does sit at 90 I would suggest it is the stat rather than the sensor, they have a habit of going every couple of years.
    Mine is on the blink at the moment, not a difficult fix either way.
    I quite often say I'm going to do things.
    Then never do them.
    JNP
    JNP's Avatar
    Jan 2011
    Basingstoke
    102
    Thanks 16Klappe, that is exactly what's happening so I ordered a new stat off Euro car parts and the gasket and will change it on Saturday.
    Hopefully will fix it
  1. Temperature gauge on an Audi80 2.0e 1994
    By yorky068 in forum Classic Audi Forum
    Last Post: 14th July 2006, 00:47
  2. Temperature Display Accuracy
    By jonathanA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2004, 20:21
  3. Replies: 1
    Last Post: 16th May 2004, 11:04
  4. NS trim needed for Mk1 Coupe('83)
    By chorlton in forum Classic Audi Forum
    Last Post: 25th March 2004, 11:45
  5. Temperature control flap linkage
    By Phil100 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th February 2004, 09:26
