EM TuningBadger5
    WillJP's Avatar
    Dec 2011
    Portsmouth
    32
    from wheels spacers question
    I fitted coilovers to my a3 a while ago now but I can't go any lower than what it is right now because the inside of the tyre touches the spring
    I want to know what size spacers i need to spot them touching, without the wheel coming out too far.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    What wheels do you have?
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    WillJP's Avatar
    Dec 2011
    Portsmouth
    32
    Only pic i have atm not sure what theyre called
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    Without knowing what your wheels spec are and what size tyres your running or what coilovers it is impossible to answer your question? Can't you just measure how far you want your wheel to come out? Then get that size spacer? Sounds quite simple to me
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    What you need to do is remove the assistance spring and then they won't touch and you will be able to get them mega low. It doesn't make too much difference to the over all ride of the car either.
    This is a set I've had (all be it for another car, I can post a picture of ones I have fitted to an A3 if you want), you can see the second spring in this one -
    If you can't be bothered to remove the assistance spring then I would suggest 15mm spacers, you can get away with 20mm but if you are running the standard tires then they may rub the arches on tight turns. I run 20mm spacers on a similar offset wheel and they finish up like this -
    Make sure you remove the rear adjuster platform too, just the spring in the seat. It will be a perfect height.
    The best fitment however has to go to Prawn
    The wheels you have there are facelift A3 Quattro Sport wheels.
    I quite often say I'm going to do things.
    Then never do them.
    WillJP's Avatar
    Dec 2011
    Portsmouth
    32
    Quote Originally Posted by s3 Hoggy View Post
    Yea but I am cazy lunt
    Quote Originally Posted by 16Klappe View Post
    That said, before the spacers you could do this -
    remove the helper spring? never thought of that.. I'll give it a go in the week.
    Let the drive shaft see the arb! ha
  1. Wheel Spacers question?
    By OwwwD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th July 2012, 20:33
  2. Wheel spacer questions
    By Davsurfa in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2009, 06:30
  3. Wheel spacer question
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th October 2008, 18:26
  4. 19's + Wheel Spacer Question..
    By Shy19s in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2008, 21:02
  5. Wheel spacer question
    By Rich-xstS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2007, 22:12
