Chris NottMonster Motorsport
Results 1 to 1 of 1
    Gizmo20VT's Avatar
    Jun 2012
    289
    GT2871R oil and water line size and setup
    Hey everyone
    Just looking for some input on what size lines to use on my gt2871r setup, which I am installing on a 1.8T AMK.
    Would 1/2" (12mm) braided telfon pipe be sufficient for a oil intlet and would I need a oil restrictor (seems like it has a internal one)?
    Would a 5/8" (16mm) braided teflon pipe be sufficient for a oil return?
    What size should one use on the water lines and do I need to clock the centre core in any specific way for the water lines (example does the return need to be higher than inlet or visa versa?)
    This is my first BB turbo and dont wanna mess it up
    Gizmo
  1. Thermostats and Water temperature
    By Wak in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st February 2007, 17:07
  2. S-Line and S-Line "Special"
    By OutLore in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th September 2006, 22:48
  3. Cambelt and water pump
    By GarryA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2006, 19:47
  4. v6 30v cambelt and water pump change what tools?
    By dummi in forum General Technical / How To
    Last Post: 30th December 2005, 10:46
  5. Differences Between New SFG and S-Line SFG?
    By DaveS3Turbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2005, 08:31
