Results 1 to 17 of 17
    Jun 2012
    42
    boost problem :O/
    after reading alot on here i decided to fit a catch can as i was loosing boost thought by deleting the pcv system it would fix my boost problems , ive new maf new n75 valve full samcos new recirc valve but i still have neg 20 on my boost gauge and im only boosting to 6-7 psi any ideas people imalmost out of faith on this car ,
    no fault codes when plugged in
    going to pressure test it tomorrow what the best pipes to do this on ????????
    any ideas ??? i know there is a leek cause of the -20 on my boost gauge ???
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Whos told you -20 is a boost leak, thats what it should be, anything under -16 so is a leak, a typical 1.8t should be -18/20. Regarding boost thats about for a a3 150bhp, that is me guessig its a a3 as youve not stated what car it is?
    Jun 2012
    42
    s3 2002 remapped few other bits , new to audis just by other cars ive owned on a psi boost gauge they have always been -10 when on idle on the gauge this is -20 , also im only boosting to 6 psi any ideas ?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Firstly its not a Boost leak if its -10 - -20 in HG at idle your engine is in vacuum, there is no boost at that stage...
    i would say that -20 in hg is normal, so the vacuum pipes should be ok.
    RIP S3dave
    May 2004
    nr Glos
    7,162
    OP: ignore vacuum.. boost is what you are missing.
    Its running on actuator pressure only.... for some reason.. be it N75 plumbed wrong, broken etc etc
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Argh, so as said the boost is defo down, when my n75 was the wrong way round i was only making actuator pressure, check that as bill said!
    Jun 2012
    42
    right had a few hours this morning before a job , reading alot last night i did a few tests run it up the road with the n75 unplugged so actuator pressure only it runs 2-3 psi on my gauge with n75 plugged back in 5-6 psi , i can see there is a massive fault now since ive had the car its been everything that could go wrong can but it wont beat me lol , actuator next ? boost feels strong but iknow its got an apr remap by awsome so should be a fair wack more than that surly ????
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Sounds like a weak/leaking Actuator....
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Agree with Dave, 2-3 PSI actuator pressure is poor. Has the actuator been tinkered with at all?
    Homer Simpson
    Jun 2012
    42
    anyone got a picture of there n75 valve so i can just make sure thats correct googled it no pics
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by cabrio boy View Post
    No, but I can tell you...
    There are three stubs in a T pattern on the N75 yes?
    One is longer than the others. This one goes into the TIP. From there, the one that is horizontal is for the feed from the charge pipe, and the one at the top is the actuator outlet.
    Homer Simpson
    Jun 2012
    42
    i dont know i bought it thinking it had great history from awsome and it seems to me guy before didnt do things properly think owner before him used awsome and he just abused it and now im putting it all right owned the car 8 months and never had the full power out of it ive had damaged pipes n75 valves alsorts grrrrrrrrrrr but it seems joys of owning an s3 lol just want it running right now !
    for ages it run 1 day at 6 psi the following day at 12 then just went off to 6 psi permanant its strong and holds the power doesnt back off now ive fitted the catch can and new n75 valve new maf new recirc it is a perfect 6 psi no more
    Custom-Code HQ's Avatar
    Nov 2007
    171
    Have you done any VAG-Com logs to see if you have a faulty boost gauge?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    RIP S3dave
    May 2004
    nr Glos
    7,162
    5-6psi is actuator, 12psi is std..... You sure its remapped?
    bill@badger5.co.uk
    Jun 2012
    42
    yes have all the paperwork from awsome, done an air test on it tonight found one of the intercooler samcos leeking feels alot stronger now thats fixed but still 5.5 psi thats with it plugged it in to vag . com i do think its the actuator now only thing left lol
    Jun 2012
    42
    as ive found leeks its moved further along in different parts a few times ive done bits and had it for a few hours running 19 , 20 psi but then following morning go out and its found its self another leek , ive deleted the pcv now and fitted a catch can and replaced all vacume hoses so it seems to have crept along the system to the actuator 6 months of owning this car it wont beat me it will be rolling roaded at its full power lol
  1. boost problems
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2005, 17:16
  2. MOVED: S3 Boost Problem
    By bampy in forum The Welcome Section
    Last Post: 30th May 2004, 23:04
  3. Boost Problems!!!! New Owner So Quite Worried!!!
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2004, 12:50
  4. boost problems - following remap
    By tim99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 12:59
  5. S3 Boost problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2004, 23:13
