Sky InsuranceJMB Retrofits
Results 1 to 14 of 14
    ras
    Apr 2010
    Sofia, Bulgaria
    7
    S3 Steering Box replacement?
    Hello from Bulgaria! Please excuse my poor english!
    I have S3 production year 2000 with APY engine... and i have a problem with the steering box - it needs to be replaced!
    Unfortunatly i cant find a steering box for S3
    My question is can i use a steering box from A3 1,8T FWD with my S3 tie rods ???
    Some people here say they fit and some say they dont - so i am asking you for help please!
    Thank you.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    The S3 has a Quicker steering rack TT ones will fit ?
    ras
    Apr 2010
    Sofia, Bulgaria
    7
    What does this mean? I could use the A3 steering rack but it will have a wider turn radius? Or it doesnt fit?
    Should i be looking for a TT 225ps steering rack or any TT will do?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    I think if you don't use a TT/ S3 then it will cause problems with the sensors for steering wheel angle. E.g ESP won't work and warning lights will be showing.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    ebay is your friend mate if you can find them... check people breaking there cars but as the guys said better off sticking with an S3 steering rack
    ras
    Apr 2010
    Sofia, Bulgaria
    7
    I will definitely get S3 steering rack if I find one...
    In the meantime maybe i will try A3 rack
    if only ESP doesn't work that's even better i always turn it off anyway
    Jan 2011
    Australia
    1,316
    Quote Originally Posted by ras View Post
    wat is the point of doing the job twice?
    ras
    Apr 2010
    Sofia, Bulgaria
    7
    Because I need the car and i dont have S3 rack yet ... S3 is rare in Bulgaria im still searching
    I have only A3 rack for now.... so i'll try it to see if it fits.
    Jan 2011
    Australia
    1,316
    buy one from the uk if u drive on the same side of the road .. not sure if they are different but i would assume so...
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,063
    Visit 16Klappe's Instagram Channel
    So much bad information; well I'm not sure if it is bad or just terribly written.
    NO 8L platform car has a steering box; they are all rack and pinion steering design. So stop saying box, you may find that is why you can't get hold of one.
    In answer to the OP's question; yes an A3 rack will physically fit in place of the S3 rack. And it will work.
    The A3's steering rack is 3.5 turns from lock to lock, where as an S3/TT/Leon Cupra R is 2.7 turns from lock to lock and any rack from those vehicles will fit. The overall turning circle of the vehicle would not change between the two racks, just the number of turns needed to get there.
    The issue with retrofitting the steering racks into facelift A3's is that some people experience issues with the ESP kicking in on long sweeping bends, because the ESP sees a difference in wheel speeds that does not correspond with the steering wheel input, because the gearing in the rack is different. So that should work in reverse for this one, because the ESP system will think you have turned the wheel more than you have.
    The steering angle sensor is in the column and not in the rack.
    I quite often say I'm going to do things.
    Then never do them.
    ras
    Apr 2010
    Sofia, Bulgaria
    7
    Thanks for the explanation. I was using box instead of rack because thats how it appears in the vagcat parts catalogue.
    My problem is that in my country there are very few S3s and its hard to find 2nd hand parts.
    Maybe a rack for TT will be easier to find... As I understand it is the same as S3 rack?
    Does it matter if its a FWD or quattro?
    Thank you for the help, again!
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,063
    Nope FWD or Quattro, any 8L chassis Leon Cupra R, TT or S3 rack will go.
    Then never do them.
    ras
    Apr 2010
    Sofia, Bulgaria
    7
    Thanks 16klappe you get a beer on me if you come to Bulgaria!
    Reesy's Avatar
    East Sussex
    3,604
    I would try and get hold of a quattro one if I were you.
    I fitted an LCR rack to my A3 quattro (to get the shorter lock to lock) and one of the hard pipes hit the prop. It did bend out the way, but I'd say you're better off just getting an s3 or quattro TT rack.
  1. power steering belt replacement
    By flange in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2011, 19:33
  2. Steering Wheel replacement
    By dalespitfire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th February 2010, 00:33
  3. Answer to Steering Rack Replacement
    By THE MONSTER in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2009, 20:17
  4. A4 1.8t Power Steering Rack Replacement and Flushing System
    Last Post: 11th November 2009, 23:25
  5. Steering rack replacement
    By phill1012k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2009, 13:07
