Badger5JMB Retrofits
Results 1 to 8 of 8
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    534
    First vag-com scan; trial version only, what are these codes?
    Hi guys,
    I'm sorting myself a full version of vag-com, but before that comes in I ran a scan with the trial version. These are the codes that came up. The car was scanned and cleared a while ago by a garage, so these should be "real" faults I guess, not just logs. I will run a full scan when I get the full version of vag-com up and running, but for now
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    16955 - Believe this is brake switch related
    P0571 - 35-10 - - - Intermittent
    16795 - Believe this is SAI related
    P0411 - 35-10 - - - Intermittent
    1) I changed the battery maybe a month ago, would this trigger this? Also, when i'm low on fuel (maybe half a tank) the car doesn't always start first time, i've heard this can cause this fault?
    2) I guess I need a new switch? Any way to see the part number I've got without removing the old one? I stuck my head down there and couldn't see where the number was stamped on the part
    3) Related again to my fuel pump issues?
    Thanks for the help guys. Will be doing some 3rd gear logs etc once I get the full version.
    Cheers,
    Aran
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I would reset the codes and see what comes back..
    Feb 2012
    Surrey
    534
    i did not know that site existing, thank you tuffty!!
    Think I might remove the SAI system anyway...will clear codes again and see what comes up.
    Thanks guys
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    Al in the stickies dude...
    <tuffty/>
    Feb 2012
    Surrey
    534
    my bad
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    All good... you aren't the only one that doesn't read them lol ;P
    <tuffty/>
    Feb 2012
    Surrey
    534
    strike 1 for Aran :P
  1. What are these codes??
    By boya in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st February 2010, 16:28
  2. VAG COM Scan what how and were
    By ex_scoobydoo in forum General Automotive Chat
    Last Post: 11th November 2009, 20:07
  3. vag-com scan
    By NOGAROS3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th January 2005, 09:23
