Sky InsuranceEM Tuning
Results 1 to 8 of 8
    Jun 2003
    west yorkshire
    90
    transfer box question
    Hi all, can anyone tell me if the Quattro gearbox will fit in a Leon cupra r with the transfer box removed, my sons cupra r gear box needs replacing and as it’s the same engine as the s3 i wanted to know if a s3/tt gearbox would work, i believe that the transfer box has an oil feed, would it be possible to plug this or can part of the gearbox casing be easily changed, any help would be grateful,
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    There is a kit available from what I understand to convert it but it won't fit straight just by removing the bevel box...
    You could also use the bell housing section from a fwd box but this could be expensive..
    <tuffty/>
    Jun 2003
    west yorkshire
    90
    Thanks for the reply, not sure its what i'm after, i wanted to know if its possible to fit a quattro gearbox without the transfer box using the leons driveshafts. thanks Mick
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    ..and I answered... the kit is used to block off the oil feed holes to the transfer box so you can use it in a FWD configuration... you cannot however just remove the transfer box and use it without modification..
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    LCR driveshafts should fit once converted... not sure what else is included in the kit but someone else asked the same question a while back and a link was posted...
    Just did a quick search and this suggests you can run the box with the the transfer box connected (no prop) with 'no problems'
    VWVortex.com - Convert O2M Quattro to FWD?
    Not sure thats the approach I would take tbh and would require a quattro downpipe to pull off I would think as the transfer box looks like it would get in the way..
    I can't find the link for the conversion kit sadly...
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,844
    Isn't the quattro gearbox shorter geared than a LCR one?
    You've got to have a laugh!
    Jun 2003
    west yorkshire
    90
    Thanks for the replys, I will look into it but may be more trouble than its worth
  1. Simple Question - Transfer box?
    By Geoff-R in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th August 2012, 17:22
  2. Transfer box oil leak
    By S3 Dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2009, 10:36
  3. Centre Diff/Transfer Box
    By Z82 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2009, 16:26
  4. Gear box question
    By Niknak in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2008, 18:50
  5. Look for a bit more sound, back box question
    By Layerz in forum Diesel forum
    Last Post: 18th February 2007, 14:34
