Volks AutosChris Nott
Results 1 to 7 of 7
    Sep 2010
    Devon
    756
    N/A s3 Got no boost...any suggestions?
    Hi all, my 2000 APY S3 is really doing my head in!!
    I have no boost, car feels like an N/A S3 there is still a small amount that makes the noise into the B5 TIP but none that you can feel while driving. If your driving in 4th at 40ish then bury your foot normally the torque puts you back in seat now it very very slowly climbs the rev range until maybe 5k then picks up a bit.
    So far I have
    Scanned for codes...Nothing there
    Electronicaly disconected the N75....No change
    Disconected MAF....No change, neither better or worse
    Stripped off all main boost hoses, TIP, DV etc in search of leaks...nothing found. Car idles correctly as well.
    Logged MAF in 3rd and 4th highest output was 177gs off the top of my head worked out at 220bhp, was 269bhp 3 weeks ago
    Unfortunately can't log boost request etc as only have unregistered lite VCDS.
    I checked the turbo, very little play but quite alot of oil on the blades and also in the red charge pipe,
    Any suggestions or ideas welcome as I'm stumped!
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    Have you logged fueling, timing etc to see what their all doing? Have you checked all the lower intercooler boost hoses? Checked all the pcv pipework?
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    • Rough Running At Idle: MAF, Ignition Coil, Spark Plug, VAC Leak, O2 Sensor, TB, CTS
    • Missfires under Boost Flashing CEL: Ignition Coils, Spark Plugs
    • Running Rich: Boost Leak, MAF, O2 Sensor, Coolant Temp Sensor
    • Running Lean: VAC Leak, MAF, O2 Sensor, Fuel Filter
    • Low Boost: Limp Mode, MBC, BOV, DV, Boost Leak, N75
    • High Boost: MBC Setting, N75, Spark Plugs, Ignition Coils
    • Cold Start Problems: MAF, Spark Plugs, Fuel Pump Relay, CTS
    • Poor Gas Mileage: MAF, CTS, O2 Sensor, AIT Sensor
    • Cat Efficiency Below Threshold: Down pipe, CAT, Rear O2, RACE FUEL
    • No Start: Battery - ECU, Fuel Pump Relay, Ground
    • Start For 1 Second Stall: Immobilizer
    • Overheating: Waterpump, Thermostat, Head Gasket
    • Oil in coolant: Oil Cooler, head Gasket, Water Wetter
    • Dies While Driving: Timing belt, Boost Leak, MISC
    • Shorts To ground CEL: Fuel Pump Relay, Bad Grounds
    • Oil in your IC/IC piping: Check your PCV system
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    Sounds to me like it's running on actuator pressure mate. If it's picking up a tad at 5k or so that's most likely a hint of boost creep causing that.
    I'd check the wiring into the N75 plug, it seems to be getting more and more common for the wiring to fail inside the insulation. Caused me no end of trouble on a trackday!
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    +1 on this.
    Check N75
    Did u take the pipes off when changing sparks. May have connected it up wrong.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    What boost is it makig?
    Sep 2010
    Devon
    756
    Cheers guys..
    I can't log boost/n75 cycle as only have basic vcds which sucks.
    Everything was correctly disconnected when changing plugs, I have also gone over every single hose coming off the DV, N75 and TIP all seems ok.
    Prawn, the wiring for the N75 if I put a volt meter across this would it give any useful information? Can't do it tonight as I'll need to borrow one from somewhere...If thats actuator psi then would that limit faults to being n75 related?
    Sooo many questions and options lol
  1. any one got a boost leak tester i can borrow?
    By audi-a6 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2012, 10:34
  2. Anyone got any suggestions?
    By AdamA3 in forum General Automotive Chat
    Last Post: 24th October 2011, 19:05
  3. inconsistant boost, not the N75, any suggestions?
    By joshW in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2008, 19:48
  4. Not holding boost.....any suggestions
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th May 2007, 21:46
  5. Change of Car below 8K - any suggestions??
    By fraz in forum Other Brands & Models
    Last Post: 5th March 2003, 17:10
