Badger5EM Tuning
    Mar 2012
    S3 APY Cambelt Hydraulic tensioner
    First time post on here, so apologies if there is a FAQ on this that my male refridgerator blindness has hidden for me.
    I have just changed the cam belt on my car. I should have remembered from my time as an Audi tech, that you do not strip the hydraulic tensioner if you forget to pop a 3mm pin in the damper prior to removal !! Anyway, i guess that i will probably have to purchase anew one (costly out here in Oz). Anyway, i reassembled the unit with engine oil, ran the car, all good for 10 km or so, then some rattling. On inspection i found that the tensioner was flapping around, albeit only a couple of mm. Sounded awful. So stripped it off again, made a few adjustments and same thing happened. What baffles me is that after leaving the car for 10 minutes or so, it goes away, then comes back at around 2000rpm. Being a stubborn type of chap, i am determined to work out why?
    Has anyone ever stripped one of these tensioners? If so, do you have pics, (schematic would be awesome) of order of things, in case i was having a senior late night moment ! Any idea of quantity of oil to add to the unit ? Or indeed what type of oil??
    Your thoughts would be appreciated
    Kevin
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    No schematic exists that i am aware of, they are a sealed non serviceable part
  1. 2001 a4 timing belt hydraulic tensioner
    By mtwallet28 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd January 2011, 18:18
  2. Checking ABF semi-automatic cambelt tensioner
    By HTC in forum Volkswagen and other VAG
    Last Post: 12th November 2004, 06:21
  3. Cambelt Tensioner - Know Issue???
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2004, 07:56
