Chris NottVolks Autos
    Omniquito's Avatar
    Sep 2012
    55
    Main bearings... What's this?
    Hi guys,
    As a continuation of chasing an oil pressure issue i dropped the sump, changed the gauze and pump and was inspecting the bottom end and came across something i am not sure what it is?
    The centre main has a "tang" like thing each side of the cap and they have quite a bit of movement in them (as far as the recess in the cap lets them move anyway).
    I assume these are normal but is being able to move them normal or does it point to a possible shell issue and loss of pressure that way?
    I dont want to just undo the cap as the bolts are £9 each!
    Also, if i was to replace this, can you do both upper and lower shells without removing the crank? Ie. insert the upper and spin it into place?
    Thanks, Neil.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    just take the dam bolts out and look!! lol.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,937
    thrust washers
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,352
    Thrust washer, its a bearing for side to side movement
    Don't remove the bolt as there stretch bolt and will need to be replaced if removed
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Omniquito's Avatar
    Sep 2012
    55
    Think I will leave the bearings alone and seal it back up with a new pump and gauze then... See what happens!
    Thanks chaps
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    You've roasted the engine twice with low oil pressure from a blocked pickup, and your not going to bother checking the main bearings even though theres an obviously discolored cap?
    TD5 Land Rover Defender build
  1. What would get bent, top arms or main bearing housing?
    By Rhencullen1989 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th November 2009, 21:16
  2. What was this furking quick Skoda??
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2009, 13:53
  3. what does this warrning light mean
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2003, 18:23
  4. So what's this forum about?
    By jesters3 in forum Detailing
    Last Post: 23rd June 2003, 21:33
  5. APR Chip - What is this?
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2003, 09:42
