Sky InsuranceVolks Autos
Results 1 to 28 of 28
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Boost gauge problems
    I fitted a manual gauge today and it sits normal when the engines off when the engine is running the gauge is way below the - on the scale ad when on boost it Dosnt make 0.5 on the scale? Car is a 99 a3 Quattro Jetex filter fmic 008 DV I teed the vac pipe on the fpr line, any ideas?
    Thanks!!
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    0.5 what?
    what units?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Bar I presume?
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Faulty gauge maybe?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    So what does the gauge read when idleing? Also is the car remapped? Btw change the feed from the fpr to the dv, if theirs every a boost leak from that area due to rhe t piece itll **** your fueling up.
    Dec 2011
    140
    Quote Originally Posted by James TQ View Post
    Faulty gauge maybe?
    1 BAR is 14psi so your gauge is never going to go over .5 , unless its chipped .
    James TQ's Avatar
    Apr 2012
    Essex
    546
    When it's on idle the need is pointing south.... Straight down, then when I rev it rises car isn't mapped and yeh I'm sure there's no leaks check and replaced a fair few pipes. It's only a cheapo gauge from eBay but just worried the vac is too strong or somthing
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    sounds like a shyte gauge
    bill@badger5.co.uk
    Sep 2012
    Aberdeen
    9
    What boost should a standard car run at. I have monitoring mine on Torque but have been getting some quite bizarre readings. Was going to get a mechanical gauge to see what readings i got from that.
    2001 A3 1.8T (ARY) Quattro
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    i see -0.7bar on idle on a stack boost gauge, and -9.3psi on my dyno logger on idle
    *guide*
    bill@badger5.co.uk
    James TQ's Avatar
    Apr 2012
    Essex
    546
    What should a stock a3 Quattro run any ideas?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    the same - its idle
    bill@badger5.co.uk
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    My s3 idles at -20pis on my stack gauge!
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    wow thats too high to be plausable unless you idle at 2krpm
    bill@badger5.co.uk
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Mine is -20 IN HG too normal idle..
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    inaccuracies of pressure gauges in vacuum I guess....
    bill@badger5.co.uk
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Hmm i thought this so i swapped for a pro sport Digital and reads exactly the same... Is that to high then Bill?
    Sep 2012
    Aberdeen
    9
    Just been out and taken an idle reading from mine using Torque app and getting around -22in/hg
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,067
    Mine's the same, around -20 on the gauge on idle. All the 1.8T's I've seen have been on various different gauges too.
    James, an unmapped TQ isn't going to be making much boost anyway, the turbo is more of a paperweight than a boost in power. I think stock boost is around 10psi which is around 0.6-0.7 bar.
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Ill wait untill I get a new gauge. What if there's too much vac what's the cause of that?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    why are you fretting about vacuum????
    bill@badger5.co.uk
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    OP doesnt mention units at all. so how can we advise.
    vaccum is measured in Inhg, which is inches of mercury at 0 degrees C. thats what should be on your gauge on the vacuum side of things. You should read about -20, or there abouts. 1inhg = 0.49psi btw, incase your gauge reads psi.
    boost is as prawn says.
    and dont take the vac off the fpr
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Ok so I got a new gauge, it won boots past 0.25bar? It's an un mapped as TQS eBay fmic Jetex filter forge 008, Is this low? Gone over all pipes no leaks? Other things to look for?
    pinci's Avatar
    A3 1,8T TQS
    Aug 2012
    Osijek...Croatia
    Mine Defi boost gauge in idle it runs at -0,7 or -0,8 in vacum...Arround 3000 rpm's the pressure is out of vacum and the car is starting to boost....A3 TQS K03S remaped at full boost around 1,2 bar...In overboost it goes arround 1,3 or 1,4 bar and in some time around 6000 rpm it falls down to 1,00 and 0,9 bar's
    James TQ's Avatar
    Apr 2012
    Essex
    546
    so mine standard isnt making 0.5bar?... this is low? any ideas why?
    pinci's Avatar
    A3 1,8T TQS
    Aug 2012
    Osijek...Croatia
    Where you have fitted T clamp and vacum hose for the gauge ?
    Maybe the gauge is ok and you installed it properly...Have you tested maybe boost leak or something...Car goes normally ?
    Stock boost I think is about 7-9 psi depends od air temperature and humidity....That aprox.. 0,5 -0,6 bar's ...The gauge readings is in your case correct
  28. #27
    James TQ's Avatar
    Apr 2012
    Essex
    546
    I t'eed it of the fpr iv gone over the engine so many times looking for leaks ad found none :/ just 0.25 bar seems low boost?
  29. #28
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    This thread hurts my brain.
    I quite often say I'm going to do things.
    Then never do them.
  1. boost gauge wiring problems
    By sean88boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2008, 23:40
  2. Boost gauge to an S3
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2004, 19:21
  3. boost gauge ?
    By jimboA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2003, 23:18
  4. Digital boost gauge
    By Mo-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2003, 23:42
  5. Fuel gauge problems !
    By S3LAK in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2003, 08:20
