Chris NottJMB Retrofits
Results 1 to 18 of 18
    Andyrew_69's Avatar
    Aug 2012
    54
    Anti Roll Bars - Which set up is best??
    Hi I have recently just fitted a set of AP coilovers and kw tie bars and poly bushed the old bars. After all this I am still not happy with the tail happy feeling that comes from the S3 when corning from side to side at speeds..... I want it to be more planted so thinking uprated ARB's are the next upgrade (as well as new tyres of course - Yokohama AD08's) on the list.
    Basically just want to know what set up people have tried and tested to get the perfect compromise??
    From what I have seen I am thinking about 22mm on the front and 19mm on the rear?? Is there any kits available with them sizes??
    Front size??
    Rear size??
    Makes and prices??
    Many thanks.....
    Feb 2012
    1,105
    what tail feeling do you mean? does it sway too much?? the best option from my own searches are the nuespeed ones which are 22mm fr 19mm rear. but they are expensive. most go for an r32 19mm rear and that sorts the roll out. some complain it makes the back to stiff and a bit tail happy. i have coilovers and an r32 rear and im happy!! daz
    Alex C's Avatar
    Lizard, Cornwall
    2,600
    Quote Originally Posted by Andyrew_69 View Post
    When you say tail happy do you mean your car over-steers?
    The s3 will under-steer on standard setup. I have Neuspeed 22mmF and 19mmR which cancelled out the under-steer. Can't remember the price but they were quite expensive i think
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Feb 2012
    1,105
    not entirely sure. im talking about the r32 rear bar only not your set up. i think its a bit twitchy for some and they opt for a bigger front. but most seem happy. i read one guy say he changed his set up because he was sick of feeling like the car was going to spin while changing lanes on a motorway lol. each to their own set up i guess. daz
    Jun 2004
    Surrey, UK.
    269
    First thing to do check the condition of all the bushes. Make sure they're still in good condition.
    If they are then have you taken your car in to do a proper four wheel alignment ?
    I'd do that before anything else.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    The S3 on stock arbs under steers loads so I'm surprised you're saying it feels tail happy. I did a track day on stock arbs and wasn't very happy. Ordered an R32 rear as soon as I got home.
    The R32 makes it stiffer at the rear and makes the car run into corners much better then before.
    It's all about the size difference between the front and rear arbs that changes how the car behaves. Tam on here changed both front and rear arbs to R32 ones and it meant his car had less roll but as the size difference between front and back was the same as the S3 he still had a fair bit of understeer.
    Understeer is deemed safe for the normal driver which is why all car manufacturers make them like that as stock.
    My advice would be to leave the front arb alone and bung an R32 rear in and you won't be disappointed.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    its odd to hear of someone experience alot of oversteer like you are.
    if thats the case you should be looking to increase the size of the front. perhaps get an r32 rear one (19mm) and look for an aftermarket front one thats like 24/25mm or something. that should do it.
    please remmeber tho, thicker and stiffer isnt always better, you will end up with a stiffer overall car, more crashy, and in extreme casses you'l make the handling worse, which was the whole point of coilovers and poly bushes in the first place, to improve grip.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    What rear tyres are you running?
    S3Zek's Avatar
    Sep 2011
    407
    I have r32 front (23 I think?) and 22 rear and I find it really good to throw it in to the bends over the stock chicken wire arb's.
    S3Zek's Avatar
    Sep 2011
    407
    Is starting to squerm a little with more power from the brembos upfront, so next is to sort the rears
    Feb 2006
    Lincolnshire
    719
    A friend of mine had a Clio SC that started to want to swap ends on itself after a change of springs (old ones snapped), but a new set of tyres sorted that out.
    I would start with the obvious stuff before changing roll bars.
    Im no setup god, but the thicker rear roll bars being advocated by some would probably make your tail happiness worse. Rather than beefing up the front and/or rear, I'd probably try a thinner rear bar, but only after checking the other stuff already mentioned.
    Stiffer isn't necessarily grippier, and setting your car up for a trackday won't necessarily be the best for the road. Depends what you do with the car too?
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    If it feels like it wants to spin when changing lanes on the motorway, I'd say that's almost certainly down to a bit of toe out at the back end. Certainly nothing to do with arbs unless you're running a massive rear bar and lowered springs on stock dampers, in which case the dampers won't be able to cope and it'll get pretty scary.
    Feb 2012
    95
    this is something i need to decide on what direction i want to go with the s3, track car and chase prawn down lol or just a fast road daily
    Vagworld's 2000 s3 apy 140k
    de-cat, Art Of Speed custom remap , forge tip, amd dv, JAP CAN!!
    13.8 @ santapod 250bhp 256lb.ft
    INSTAGRAM: CHRIS_VAGWORLD FACEBOOK: CHRIS AT VAGWORLD
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Vagworld View Post
    Mine is a fast road daily and I'd recommend just an R32 rear. But if you want a track car I'd suggest the adjustable arbs.
    S3 Build Thread
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    The H&R setup will give the S3 a very well balanced feel, if you want more oversteer the Eibach bars are a good option.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Oct 2011
    760
    Are these the correct poly bushes for for the mk4 r32 arb we run on the s3?
    Volkswagen Golf Mk4 4motion Powerflex Rear Anti Roll Bar Mounting 19mm Poly Bush Kit PFR3-511-19 Only 27.36
    any other suggestions?
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,901
    while we are on this whats the best set up for an a3, id like a nice flat drive through corners, i have got coil overs but still get that feeling that the car could be a little stiffer / flatter through corners.
    car is used as a fast road car.
    k03s/k04 hybrid a3 275bhp 293lbft
    vr6 mk2 golf gti
    fellow north east members add your name to this list.
    http://www.audi-sport.net/vb/north-e...%2A%2A%2A.html
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,275
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by jezzy View Post
    Volkswagen Golf Mk4 4motion Powerflex Rear Anti Roll Bar Mounting 19mm Poly Bush Kit PFR3-511-19 Only �27.36
    I'm almost certain they are mate....
    My suggestion would be to buy them from here if there in stock - free P&P
    Powerflex PFR3-511-19 ANTI-ROLL BAR BUSH 19MM (2) - Regals Motorsport Ltd
  1. what are the best anti roll bars?
    By andrew-247 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2012, 23:32
  2. Anti roll bars which ones?
    By sp84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2011, 20:58
  3. which anti roll bar do i upgrade to?
    By philreed52 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2011, 17:41
  4. Do I need anti roll bars? Which ones?
    By j7yob123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2011, 16:18
  5. Front anti roll bar - which should I go for?
    By Spacecowboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2007, 15:07
