Sky InsuranceAH Fabrications
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,307
    Fuel trim help please.
    I have had the engine check light come on twice now.
    When checking with vcds I get the error
    17544 - fuel trim bank 1 (add)
    P1136 - 35-00 - system too lean.
    After the first time it came up I changed the MAF for a brand new genuine one. Thinking this would be the problem. However got the error again yesterday.
    I have also recently replaced the MAF plug with one I got second hand as the one on the car had broken an was held on place with tie wraps. I have a good connection and all of the wires were soldered and sealed with get shrink.
    Can anyone suggest what could b causing this? Am I barking up the wrong tree with the MAF?
    Thanks.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Lewis583's Avatar
    Mar 2010
    833
    I'd say vac/PCV pipe leaking. There are some under the inlet manifolds that are favourites for perishing/splitting.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,307
    I have replaced most if them with silicone not so long ago actually so could well be the culprit. I did double check anything not replaced was in good order and all connections were tight but bet I have missed something.
    2001 S3 (AMK)
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,307
    Had a look at hoses and found one with a nice pair of splits in it. Sealed it up with some silicone repair tape. Which seems to have done a good job of sealing it.
    Only done a few miles since but no sign of error code.
    Fingers crossed it is all it needs.
    2001 S3 (AMK)
  1. air in fuel line help please
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd July 2011, 20:37
  2. Trim specs. Help please. new to Audi
    By oztek tim in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st October 2009, 10:01
  3. Serious help please - got a fuel leak
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2008, 13:25
  4. Removing scuttle panel trim...help please
    By evotista in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2007, 22:57
  5. A6 2002 - fitting parrott - help with trim removal please!!!
    By milo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th August 2005, 15:00
