Sky InsuranceJMB Retrofits
Results 1 to 7 of 7
    Snash7's Avatar
    May 2012
    Horley surrey
    84
    Is it my wheel bearing. Can someone help
    In the last week and a half ive had this slight rumble/ humming noise i cant pin point where its coming from but think its deffently the front. Ive jacked the car up and had a wiggle but didnt think there was much or any play in the wheels.
    Im sure it is the wheel bearings tho.
    Has anyone had there wheels bearings replaced cant find what it cost's in parts plus labour
    As the sound is doing my head in now.
    Once this and the rear axel bushes are done i can finaly start to buy some performance parts instead of replacing broken bits
    Thanks grant
    A3 1.8t agu 1998
    phil miller's Avatar
    Sep 2012
    Devon
    843
    have you tried to spin the wheels to see if you can hear the rumble? try front and rears, its not uncommon for the noise to be caused by a tyre being out of shape
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Mate I have a droning noise coming from the front of my car, I'm pretty sure it is the wheel bearings, I'm going to buy the bearings off eBay and get a guy in salfords to do them, he is an audi vw India specialist who's pretty good
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Front wheel bearings require a press to get them in and out... have done a few... you will need to take the carrier off to get access to the bearings... this involves undoing the hub nut, lower ball joint, removing the brake caliper and disc, undoing the suspension strut, and undoing the track rod end...
    Once out you press out the hub flange, then press out the old bearing... press in the new bearing, press in the hub flange and reassemble...
    Around 1 to 1.5 hours work depending on how easy the bearing comes out... they can be a pain... if competant enough a DDIY mechanic its not difficult to get the carriers off, you can then take them to your local garage to get the bearings sorted and you just need to refit when done...
    Haynes manuals are worth buying
    <tuffty/>
    kelk11's Avatar
    Feb 2009
    102
    I've recently had both bearings replaced, was unable to tell by spinning the wheels whilst jacked up, but made a hell of a rumble whilst driving. I was charged £30 for the parts and no more than £50 labour per side
    Snash7's Avatar
    May 2012
    Horley surrey
    84
    Quote Originally Posted by Grale1 View Post
    Teah its doing my head in now. Just had cambelt and water pump 3 weeks ago then tax, MOT and rear shocks done in last week pain in the ass but at least i know there done.
    really i tryed looking for a vag specialist around but couldnt find anyone do you know him or just heard cheers mate.
    Thanks tufty appreciate it if i had abit more knowledge i would give it ago but best leave this to someone who knows what there doing lol
    Jun 2012
    Redhill Surrey
    635
    I use him for a few things like vcds stuff, I will be getting him to do my wheel bearings
  1. can someone help me
    By g60pj in forum General Chat
    Last Post: 25th February 2010, 10:47
  2. CAN SOMEONE HELP ME!
    By S3 SAF in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2007, 10:23
  3. can someone help me out with a part number please
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th February 2006, 20:22
  4. Can someone help me please
    By imported_ANNANBHOY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2005, 14:16
  5. can someone help me start my audi?
    By treetop3 in forum General Technical / How To
    Last Post: 16th June 2004, 10:47
