Sky InsuranceEM Tuning
Results 1 to 7 of 7
    Jun 2012
    Redhill Surrey
    629
    Add Grale1 on Facebook
    Rear brake light help needed
    I just put preface lift lights on my car this afternoon, bought second hand. The problem I have is the drivers side all works fine, the passenger side the brake bulb was blown so changed it using one from old cluster, and it doesn't work (brake light) now if I put the light unit from drivers side to passenger side the passenger side works and drivers side doesn't, I've tried all light units and its all the same out come, I've checked the brake fuse and that's fine, now I'm stuck to where else to go,
    any help would be great, a3 1.8 AGU if this helps
    Jun 2012
    Redhill Surrey
    629
    Could this be the brake pedal switch?
    Jun 2012
    Redhill Surrey
    629
    Anyone with any suggestions? Kinda need some brake light lol
    phil miller's Avatar
    Sep 2012
    Devon
    843
    If the brake lights work on the drivers side and not the pass side, and if when the drives bulb holder is in the pass side it works then it can only really be the bulb holder is faulty, its late and im tried i hope i have read it correctly????
    Jun 2012
    Redhill Surrey
    629
    I'm still trying to find info on what it could be, thanks for your in put tho mate, I've tried 3 different bulb carriers, think ill have to take it to garage and get them to put the vcds on and see
    Aug 2012
    86
    did they work previously?
    Jun 2012
    Redhill Surrey
    629
    I got my light problem sorted, it turned out to be a bad brake light bulb, had 4 bulbs none worked till new put in, it's always the simple things lol,
  1. Help with rear brake light problem please?
    By snorkelboy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th September 2012, 16:32
  2. Replies: 16
    Last Post: 10th September 2012, 18:15
  3. Rear Brake Light - HELP!
    By luvie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st February 2011, 18:17
  4. Replies: 4
    Last Post: 5th November 2010, 18:15
  5. Rear Brake Light DIS warning
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2004, 17:19
