EM TuningChris Nott
Results 1 to 8 of 8
Thread: Forge 007p Help
    B1GW1L's Avatar
    Sep 2012
    Waterlooville, Nr Portsmouth
    98
    Forge 007p Help
    Hey Guys
    Just got my 007p delivered (thanks to DPM) just wanted to know what spring i should run and if i should use any plates?
    Currently running 255 BHP on an s3 Bam
    Thanks in advance
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    899
    Add Vex182 on Facebook
    Yellow for stage 1, green for standard so sounds like yellow will be fine.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    B1GW1L's Avatar
    Sep 2012
    98
    Cool and what about the plates leave them out?
    Vex182's Avatar
    Apr 2012
    Hinckley
    899
    Does not need any extra tension on the spring, usually stage 2 and above will require more tension on the spring.
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,083
    Visit 16Klappe's Instagram Channel
    Yellow spring for stage 1.
    If you've got stage 2 AND a Forge actuator then yellow and a shim, otherwise I'd stick with yellow personally.
    I quite often say I'm going to do things.
    Then never do them.
    B1GW1L's Avatar
    Sep 2012
    98
    Okay Guys thanks for the advice
    B1GW1L's Avatar
    Sep 2012
    98
    Well I've fitted it and all is good thanks again for your help
    Vex182's Avatar
    Apr 2012
    Hinckley
    899
    That's alright, what we are all here for!
  1. Replies: 8
    Last Post: 9th April 2012, 21:46
  2. Replies: 0
    Last Post: 3rd March 2008, 12:10
  3. fitting forge 007p is it much of a job to fit??
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2007, 13:12
  4. Fitting a Forge 007p?!
    By Cossie_boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2007, 20:34
  5. People With Forge FMIC - Help Please
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2007, 13:51
