Forge 007p Help
B1GW1L
Waterlooville, Nr Portsmouth
Hey Guys
Just got my 007p delivered (thanks to DPM) just wanted to know what spring i should run and if i should use any plates?
Currently running 255 BHP on an s3 Bam
Thanks in advance
Does not need any extra tension on the spring, usually stage 2 and above will require more tension on the spring.
Yellow spring for stage 1.
If you've got stage 2 AND a Forge actuator then yellow and a shim, otherwise I'd stick with yellow personally.
6
768
39
3K
943
DPM
23
2K
