Chris NottBadger5
    Feb 2012
    20
    ABS Light + MOT run out :(
    Hi guys, dunno if you can sort my
    problem or not, but my ABS light has been on for quite a while now and I can't find the problem.
    And it's that time of year where my MOT is due. I've checked the fuses on the battery cover, cleaned the contact points on the sensors but still no luck.
    I was wondering if anyone could give me a list of possible
    solutions or a way to get around it for the MOT.
    And help is much appreciated, thanks again
    Ryan
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    889
    Add Vex182 on Facebook
    Best thing would to be get it plugged into VCDS with someone and find out what fault codes are showing up.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
  1. ABS light on - failed MOT
    By bertracoon in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2011, 14:21
  2. ABS light wont go out..
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2010, 16:26
  3. ABS LIGHT ON
    By imported_Beanflick in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2005, 19:50
  4. ABS Light....
    By Shaq in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2005, 14:02
  5. Finally my ABS Light problem is sorted
    By rickparmar in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2004, 20:40
