Monster MotorsportBadger5
Results 1 to 25 of 25
    Jan 2007
    192
    S3 Exhaust Manifold Studs.
    Im yet to find out if the one missing is just missing or sheared off.......if its just one missing to save all the hassle of taking head off will it still blow? Im hoping its just worked loose as the 2 turbo bolts did and one of the manifold ones were loose also.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,274
    What's missing? A bolt from the mani to the turbo (there's 3 of them), or a bolt from mani to head?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jan 2007
    192
    When i got there and they looked at it there was only 1 bolt left in turbo and that had 2 threads before that was out, its was leaning back, maybe this is where the coolant leak is from the water ffed/return pipe.....
    Mainfold to head has 1 missing also and there was another loose.....
    Westy's Avatar
    Dec 2008
    17,274
    Quote Originally Posted by marka3130 View Post
    If it was just the mani to turbo bolts I'd say just loctite some new bolts in as I had the same issue before changing to studs and nuts instead. As the mani to head bolts seem to be an issue to you might as well whip the head off and just replace the lot with new studs and bolts. Use the OEM ones as they are the best and made for the heat from the turbo, engine, and mani.
    S3 Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,378
    i had one snap from manifold to head and it made an awful farting noise under load.
    TD5 Land Rover Defender build
    Jan 2007
    192
    Right ok, i will speak to the guy and see what he will charge to take head off. Is it many hours to do it?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Personally, I'd say it's an awful lot of work for one nut. If it were me, I would leave it, see how it behaves and then make a decision.
    £150 in parts alone for head off and on. Seems a bit steep for a nut that most likely won't make a difference.
    I left one off my A3 when I did the K03S conversion and it never made a sound.
    Homer Simpson
    Jan 2007
    192
    Ok Welly nice one, if it turns out to only be one i will leave it then to be honest. Seems stupid i know what you mean afterall there are 12 other bolts lol.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I'll probably be openly flared as a bodger lol - however my methods have always worked for me.
    Leaving it and seeing involves marginally more work than having the head off. If you do test it and it's bad - then it's not much work to get back to where you are now.
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,274
    Not sure as I had my whole engine out for a rebuild.
    S3 Build Thread
    Jan 2007
    192
    Yeh true, im hoping that its just fell out not sheared, even so one bolt missing i would imagine would be ok, just thought id see if anyone else has done it.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    It's not a quick job lets put it that way. Especially if everything is there that's supposed to be. I have strategically removed stuff over the 10 times my head has been off to make it a quicker process lol.
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,274
    It sounds more then just 1 nut!
    When i got there and they looked at it there was only 1 bolt left in turbo and that had 2 threads before that was out.
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Quote Originally Posted by Westy View Post
    lol
    OP, just get the damn turbo on and tight with new nuts. mine came loose on the nurburgring and the sound was horrendous!
    once you know thats ok you can asses the severity of the manifold-head. depending which mani-head bolt it is a mech might be able to get to it. obv you need to be consulting your mechanic.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Sorry, what are we talking about here? I'm confused.
    The bolts are from the manifold to the turbo. 3 of them. Made of some sort of high heat tungsten material. E11 tops and are an absolute nob.
    The manifold to head flange doesn't have bolts, it has studs. Them there are copper nuts that wind onto the studs to secure the manifold to the head.
    If it's one of the studs, I would say it is very unlikely to have sheared. bolts/studs only tend to shear off from excess weight or pressure - not from head. I would guess the stud has come loose from the head with the nut still on and then fallen out.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Agreed, but I'm talking about the manifold to head flange, not the turbo. The turbo mani can be done piece of piss. It's the mani head flange thats the pain.
    If they know one is loose as well, that indicates to me that it can be got to to be tightened if you see what I mean.
    This has all got a bit confusing :/
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    lol
    What he said. That's what I was trying to say.
    Thanks Karlos lol
    Homer Simpson
    Jan 2007
    192
    Sorry guys, basically turbo has 3 bolts in a triangle shape, 2 of those have come out and turbo is hanging on one, ALSO there is one missing from mani to head, so these unlikely to sheer? 1 was loose also.
    Westy's Avatar
    Dec 2008
    17,274
    I understood you first time mate
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    i always use the terms 'nuts' and 'bolts' loosely (no pun intended) obv the turbo-mani is bolts. the mani-head is studs and NUTS.
    OP:
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I can't help being marginally retarded.... lol.
    The studs are unlikely to shear dude as they have lots of support from the others. Bets are it's just wound out.
    Homer Simpson
    Jan 2007
    192
    Fingers crossed
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,070
    Visit 16Klappe's Instagram Channel
    Re: S3 Exhaust Manifold Studs.
    Manifold studs can be done with the head on as long as you aren't a spam fisted spastic and can be classed as a mechanic.
    My father and I did three in the space of 6 hours using left handed drill bits and proper easy outs, much better than disturbing the head gasket.
    Too many people give up too easily, which is why I never trust garages to do anything. I won't even have the Rapid Fit next to work fit tires for me.
    I quite often say I'm going to do things.
    Then never do them.
    "Stick a V8 in it!"
    15,378
    I've taken the exhaust manifold off two 1.8T's now, and both had snapped studs, so i wouldnt say its entirely unlikely. Age, heat and thermal cycling puts a lot of strain on the metal.
    One i had the head off to fix, the other was out the car so i managed to drill it out and sort it with the head on.
    Had i had a nice right angled drill like Jardos dad above, i could probably have managed the first one without removing the head too.
    Nov 2011
    Sturminster Newton
    190
    this is all very helpfull as I have just discovered that my manifold is cracked, well not just discovered it has just happened
    A3 1.8TQS Minge blue
    Mods: AP coilovers, Strut Brace, Merc wheels, S3 brakes, hopefully going BT soon
  1. sheared stud in exhaust manifold to turbo
    By kaos in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2012, 16:58
  2. HIgh Flow exhaust manifold.
    By noslojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2011, 13:51
  3. Exhaust manifold gasket, studs and nuts.
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th April 2010, 16:30
  4. S3 Exhaust Manifold - Uprated Options?
    By funkymofo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2006, 19:13
  5. RS4 Exhaust manifolds
    By abmunro in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th February 2005, 12:29
