EM TuningVolks Autos
Results 1 to 14 of 14
    Omniquito's Avatar
    Sep 2012
    55
    Opinions on my big end!! Haha
    Hi all,
    2000 APY S3 on 220k FSH
    Long story short:
    Oil pressure light, blocked gauze, new gauze by garage, oil pressure light even worse and strip to find gauze 100% full of garage sump sealant!! Grrrr
    Dropped my sump off and wondered if you more knowledgeable folk would have an opinion on the centre main bearing cap...
    Its darker in colour than the others but cant work out if its from friction or simply a lot of miles worth of long life oil gunk in that particular area (maybe a return gallery in that area?)
    Please see the pic below:
    For a laugh, heres what came out of my gauze in the first instance...
    And heres the gauze 100 miles later after the garage had finished with it!
    Cheers, Neil.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Darker normally means its seen heat but difficult to tell as the attachements are too small...
    If its seen heat (through running dry) then its a fair chance its worn the bearing and taken the crank with it....
    <tuffty/>
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    does it knock?
    stethoscope?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    Remove the bearing cap and have a look.
    TD5 Land Rover Defender build
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Don't forget to replace the bolts if you do owt with it... I have actually seen a cap come loose and end up through the back of the block... not a good day out..
    <tuffty/>
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    <tuffty/>
    Worth adding that that was not because they had been removed and refitted with old bolts however.
    Homer Simpson
    Omniquito's Avatar
    Sep 2012
    55
    I doesnt knock, thank fully.
    You say that i have to replace the bolts but the one that came off wasnt cos the bolts were reused?
    How flexible is reusing the bolts?!? Lol as they are bloody expensive!
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Omniquito View Post
    How flexible is the side of your engine when something hits the crank and flies through it?
    Replacement engine is a bit more bloody expensive.
    My 2 cents having seen this first hand (And I still have piece of the crank cap from my mate's engine).
    Fix cheap fix twice my friend.
    Homer Simpson
    Omniquito's Avatar
    Sep 2012
    55
    ... I asked for that! Lol
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    consider that a sort of cyber-slap.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Not at all mate, I'm not trying to be cocky or anything like that. However it does pay to point that out. It's a small cost versus the implicated cost in case of failure.Ultimately it's up to you.Would you take off a timing belt that had done 40,000 miles and put it back on?
    Homer Simpson
    Sep 2012
    67
    Full of garage sealant? So can't you sue them for brand new engine?
    "Stick a V8 in it!"
    15,389
    the bolts are £1.48 each.
    Best case, you remove the cap, the bearing is perfect, you spend 3 quid on bolts and refit.
    Worst case, you remove the cap, its scrapped and you need a new engine or a full rebuild anyway so 3 quid doesnt matter.
    Omniquito's Avatar
    Sep 2012
    55
    Thats cool Welly, i knew you werent bring horrible
    As for the garage, it is owned by a friend and hes the only one i trust...
    However, he did say it was something you have to watch out for! Haha
    Seriously though, he would of got one of his monkeys to do it and im not happy, hes away for two weeks so will be taking it up when he gets back for a refund.
    Aragorn, i was told they were 8 quid each stretch bolts so was a little worried but if they are that cheap then no probs!
    Thanks guys
  1. Would you replace big end bolts?
    By Omniquito in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2012, 20:09
  2. Head, main and big end bearing tightening sequences
    By aniesigh in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2012, 16:58
  3. Replies: 0
    Last Post: 4th August 2010, 11:23
  4. PRICE OF BIG END BEARINGS
    By 20vtmk3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2008, 19:26
