Chris NottAH Fabrications
    Apr 2012
    93
    Clutch bleeding help...
    hi all i need to bleed the clutch on a s3, i hade the brake master cylinder changed a few week ago but i dont think the clutch was bleed propley as the gears seem to be crunchy, i dont want to bleed the brakes again just the clutch, can i do this on my owne with an ezzbleed ? do i just connect the easybleed and open the nipple on top off the gearbox then close it? do i need to press the clutch at any time or do i need some one in the car pressing the clutch? the brakes are a real pain to bleed and im worried if i try bleeding the clutch ill lose the brake peddal again. any advice, thanks in advance..
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,930
    yeh just do what you described and it'll be fine.
    Shouldnt need to touch the clutch pedal, but you might have to do it a couple of times to get a good pedal.
    TD5 Land Rover Defender build
  1. Clutch switch help
    By Jay in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2008, 17:25
  2. clutch problem...HELP!!!
    By cornish_a3_turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2008, 23:33
  3. CLUTCH PROBLEM HELP audi tt 225
    By davidjohngarty@yahoo.co.u in forum TT/TT-S/TT-RS Forum
    Last Post: 30th November 2007, 09:55
  4. 1st and 2nd Gear Stiff, Clutch Worn? Help
    By shawshankuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2007, 23:10
  5. clutch gone, help?
    By spleenboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2006, 20:39
