JMB RetrofitsAH Fabrications
Results 1 to 9 of 9
Thread: Oil catch tank
    Jun 2004
    Surrey, UK.
    269
    Oil catch tank
    I want to simplify the rat's nest of hoses under the bonnet and not feed oil laden air back into the inlet.
    I've read the sticky - it recommends one with 19mm outlet and inlet. Most seem to be 15mm. Will a 15mm work ok ?
    I'm considering VW GOLF GTI TDI VR6 SILVER SQUARE OIL CATCH TANK 9MM & 15MM FITTINGS INCLUDED | eBay
    for my S3.
    fs
    Oct 2011
    760
    i have a similar can, its too big.
    right pain to fit(finding space to fit it)
    i just did up the hoses real tight and it works fine.
    try getting a smaller tank.
    i think superkarl uses exhaust baffling in his catch can.
    that reminds i must get some.
    Jun 2004
    Surrey, UK.
    269
    Thanks Jezzy, the search goes on
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    538
    Saikou Michi Stage 3 Can: OCC Stage System Explained
    or
    42 Draft Stealth Can: 42 Draft Stealth Oil Catch Can - Golf Mk2/Mk3/Mk4
    I'm currently deciding between these two also
    B1GW1L's Avatar
    Sep 2012
    Waterlooville, Nr Portsmouth
    98
    Quote Originally Posted by Squirrelofdoom View Post
    or
    Ive had to look at this as, someone used a beer can on my s3 ..... well i managed to get one made for me to my own spec for £140 + £10 P&P its a baffled vented can. 1 litre with viewing tube and vent filter and inlet/outlet is 19mm
    Give lee a shout @ info@tigweld4u.com he can do you a quote and to your own design and is very helpful
    I found the lead time for both the saikoumichi and the 42 draft was too long for me but if your happy to wait there a good solid choice
    Once received ill post some pics!!!
    S3 Paul's Avatar
    Oct 2006
    2,764
    Ive been talking to a fabrication/tuning place i use about the cans they use ... its a vented can which is hard to describe ...
    I will try and draw it up later... see what people think
    Noggy Blue 2001 S3
    B1GW1L's Avatar
    Sep 2012
    98
    Heres an image similar to what i get made for me:
    Jun 2004
    Surrey, UK.
    269
    I thought the £80 stealth one was expensive for a metal can and some perforated metal, the alternative is £140 !
    What would be the downsides of fitting the 15mm outlet ones sold on ebay ?
    Oct 2011
    760
    tight fit but works.
  1. Are Oil Catch Tanks Any Good?
    By S3 Vermin in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2009, 22:49
  2. Oil catch tank on a TDi
    By Teejay in forum Diesel forum
    Last Post: 15th September 2008, 22:21
  3. Oil catch tank on a TDi
    By Teejay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th August 2008, 17:34
  4. Any one tried fitting an oil catch tank on S3
    By 4real in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th August 2008, 17:30
  5. Oil catch tank???
    By Biglockie in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th February 2007, 14:52
